88' Cold Start Elimination ----> ARAP bin woes...
Old Nov 3, 2002 | 10:21 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i want eliminate the CSI on my 88' ROC. well here we go. i have disconnected it and works great while hot, no probs. the problem arises when i try to start cold (in the morining) it will not start. ok then. i reconnect the injector and it fires right up. i go ahead and burn an arap bin on to a prom i have laying around. the problem i'm having and wondering is..... when i have that the arap bin loaded on the prom the drivers side fan is always on. the check engine light is not on. i load up the stock bin and all is normal. all i want to do is eliminate the csi and have good cold starts. anyone have a "good" 89' bin laying around? maybe all the arap's i'm downloading are corrupt or something? can anyone please help:hail:
Old Nov 3, 2002 | 10:38 PM
Car: 1988 IROC-Z
i did some more searching and found something of the a/c switch being n/o on f-bodies and n/c on y-bodies. i think that solves the fan problem. i have a 88' IROC 350 TPI, A4, 2.77 . what's the bin that matches my combo except in an 89' equivalent? where can i also get a good arap? my car also idles funny with the arap i have(lopey). thanks again guys.
Old Nov 4, 2002 | 01:05 PM
Morley's Avatar
Stick with the ARAP and just click the check box for N/O in winbin and reburn the chip.
Old Nov 4, 2002 | 02:51 PM
Car: 1988 IROC-Z
thanks for the reply. ok... everything seems to be working now. the only problem i'm having now is, only the drivers side fan comes on. the passenger side does not come on. i have set #1 & #2 to come on at the same temperture. what am i doing wrong? thanks for anyhelp.
Old Nov 4, 2002 | 09:00 PM
Guest
Guest
Posts: n/a
Only one fan is controlled by the ecm. The passenger side fan is controlled by the switch in the passenger side head.
Old Nov 4, 2002 | 10:36 PM
Car: 1988 IROC-Z
i was afraid of that. i just took a look at the wiring digrams for the dual fans and that was the result . i guess i have to do some re-wiring to get the comp to control both the fans. i burned a AUJL bin. now it turns 3-4 times before it fires up. what can i do to shorten crank/start time. thanks again guys.
Old Nov 4, 2002 | 11:14 PM
Car: 1988 IROC-Z
i've done some more searching. i found something about Crank fuel PW multiplier vs. referece pulses. 89' AUJL bin
this maybe what i need to modify to shorten start time.
i don't know what values i should enter in what value field.
edit: i think i know what i need to do but winbin is not letting me increase the values. in 1-8 or any other box for that matter.
image included
Attached Thumbnails 88' Cold Start Elimination ----> ARAP bin woes...-winbin.jpg
Old Nov 4, 2002 | 11:44 PM
Car: 1988 IROC-Z
i can't change the values in the 1-8 fields. i don't know why???? anyone else have this problem? i highlight the value box and use + and - keys. they do nothing. i even tried maunally entering the values and still nothing. can someone help?
Old Nov 5, 2002 | 02:16 AM
Morley's Avatar
Ok, this is going to come across as stupid, but.. which +/- keys are you using? It may not work with the ones on the keypad, I don't know as I use my laptop to do my edits. Try using the +/- at the top of the keyboard and see if it works then.
Old Nov 5, 2002 | 08:15 AM
Car: 1988 IROC-Z
i was using the one's on the keypad. it was late yesterday and forgot about the other ones. the ones up top work fine . sorry for so many questions but i'm trying to get more into the Prom burning :nods:. has anyone made the stock rev limiter $6E work under winbin? i try and the when i re-open it the value instead of 5500 RPM is shows 37.25 RPM ? the hex value also has also changed obviously. thanks again for the heads up Morley.:hail:
Old Nov 5, 2002 | 12:27 PM
Morley's Avatar
Thought that might be it, you get used to the key pad and forget that a lot of older programs don't recognize it.
I've never tried to mess with the rev limiter but you should just move the hex address up or down until the RPM matches what you are looking for, least thats how other RPM/MPH windows work.
Old Nov 5, 2002 | 03:36 PM
goneracin's Avatar
There is also a "crank fuel vs temp" table in winbin. I have used that with pretty good results. Just dump in more crank fuel at the engine temps you have issues.
Bob
Old Nov 5, 2002 | 09:43 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I agree with Goneracin. But also move the values up in that table with the multiplier vs ref pulses. Should start sooner.
On the other hand, you may need to take away fuel in the crank fuel PW vs coolant. I have the exact same ride you have, messed around wiht that table, but not much help. Mine starts opposite of yours; fires great cold, but cranks longer when warm. I was adding fuel in that table, but no help. Went back to the ARAP values, and moved the multipliers up in the ref table.
Do a search on "ARAP cold start cranking" or so, lots of posts on this topic.
On the dual fan setup, might not want the ECM to control both fans at the same time. They draw lots of power, an can really tax your electrial system. Also, the ECM coil driver may not be able to drive 2 coils. Just install a lower turn-on fan switch for the secondary fan. You could stick it in the radiator or just replace the factory switch. If you can keep your ride cool with just one fan, more power to ya!!!
Old Nov 8, 2002 | 01:20 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Good to hear another CSI-to-ARAP success story.
On that rev limiter and WinBin, that's a bug in the WinBin problem. You'll probably have to go in and edit the hexadecimal directly. Problem comes up when you have a 2-byte 'word' as a value. Happens with FI size also in some cases. Easy to fix, but...
...Will there be any future work on WinBin? I'm guessing not, been stagnant for a while...
Old Nov 8, 2002 | 01:44 PM
Car: 1988 IROC-Z
Mike,
Good call on the coil issue. I've never had given it much thought. i have left the fan wiring alone.
Craig,
I thought that there was a bug in the program. since i'd change it and when i saved and re-opened the values were significantly diffrent. even manually edting them will not work.
i'd be very nice for an update, but i can't really complain. without the software working as is i couldn't have done what i did .
i need to work on my cold starts now(turns over 4-5 times) . warm starts are now acceptable(1-3 turns).
Old Nov 8, 2002 | 02:23 PM
Car: 87 T/A
You check the archives here, you'll find something about the addressing for the crank times. Thought I remembered that there was a part of the table not included in the ECU file. Look around, you'll find it for sure.
https://www.thirdgen.org/techbb2/sho...ap+crank+times
Maybe it's been fully addressed there, not sure what else came in...
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
