Anyone using the Xtronics ROMulator?
Old Nov 7, 2002 | 11:08 AM
Elevens's Avatar
Just bought one, the ROMulator programs fine but my car doesn't like it - it runs in Limp home only. You just replace the ECU chip with the ROMulator cable, right?
Thanks, -Bill
Old Nov 7, 2002 | 11:16 AM
funstick's Avatar
call george there has been an issue with the header ribbon cable. also make sure the the red stripe represents pin 1. here is goerges number.or call who ever. lol. just call xtronics.
1-785-841-3089
see you later.
Old Nov 7, 2002 | 11:25 AM
Elevens's Avatar
1-785-841-3089
see you later.
You replied in only 8 minutes! Thanks! I call George.
Old Nov 10, 2002 | 10:00 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Let us know how well it works and whether or not you work out all the bugs. Haven't seen anyone comment on how well or if it actually works.
Old Nov 11, 2002 | 12:52 AM
funstick's Avatar
i have one it works fine on c3 ecms. im gonna be using it tommorow with a p4 1227749 so then ill have a definate yes or no on that one for sure. ive used it on hondas with no trouble and they use a 27c256 so if that any indicator then everything is honkey dorey.
Old Nov 11, 2002 | 01:59 PM
rooster433's Avatar
wow hondas?
could you refer to me where you would pickup some honda tuning software?
Old Nov 11, 2002 | 02:20 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Tried running one on my 749 bench... 2 different romulators, 2 different laptops... no go with either in any combo. Bench works just fine running my flash. good luck. Bob
Old Nov 11, 2002 | 03:54 PM
funstick's Avatar
must need to have a resitor value changed ill check into that. this is with the new romulator correct. if its not emulating then you need to pitch a holy **** fit. i know i will if mine doesnt. i also think it might have to do with the mecal adapter if it isnt working. with the c3 ecms if its not super tight with the pins then it wont work at all. maybe ill rig up a 28 pin header to slip directly to the ecm this might be the problem to much signal latency. im headed out to try my romutlator now did you try to emulate with a c3 ecm like a 747 ? also were you geting a RED led with ECM power on with the romulator plugged into the ecm but disconnected from the laptop ??
roosetr what type of honda make modle and ecmre you rworking with ?
Old Nov 13, 2002 | 02:50 PM
Elevens's Avatar
Had to send the ROMulator back for inspection. It refused to work with my 727 (730) ECU.
-Bill Rauch
yellow73bb
Oct 28, 2004 01:50 PM
brennanw
24
Jun 8, 2004 08:22 PM
Mangus
89
Nov 29, 2003 09:03 PM
ski_dwn_it
Jun 19, 2003 08:00 AM
88TPI406GTA
29
Nov 21, 2002 06:00 PM
