Modified 91 TA has hesitation and bucking at WOT (Only)
Old Dec 13, 2002 | 08:05 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I have a 1991 TA TPI 305 w/5 speed.
It is modified with:
SLP headers and 3" exhaust
Crane Cam
SLP intake runners
SLP air foil
SLP High Performance chip
Crane roller rockers
TPIS big mouth intake
Accel 23# injectors
AFPR set at 47 psi
Racetronix high flow/pressure fuel pump and wiring harness
New fuel filter
All new ignition items (wires, cap, rotor, etc)
Jacob's Pro Street Ignition
The car is very fast and responsive except at WOT.
At WOT the car jumps and hesitates. Right before WOT everything is fine.
What could be causing this?
I am going to put my stock chip back in to see if the advanced timing is a problem or maybe something else with the chip?
I already put the ignition back to the stock coil and it didn't make a difference so it is not my Jacob's Ignition.
I am thinking that I need to get into some PROM burning and have began reading the basics.
What should I begin to change in the programing to help with my problem?
IAC
Injector Constant
WOT tables
Thanks for any suggestions.
Old Dec 14, 2002 | 11:35 AM
87_TA's Avatar
Before I even went there I would be sure that you are not running out of fuel.Filter need changed? Pump going bad?
Old Dec 14, 2002 | 12:08 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Please read my post????
I mention what I have changed already, including these two items.
What I have been told so far is that I am bogging down because I am running too rich for now before the supercharger goes on.
I was advised to change the prom settings for the injector constant.
Just wanted someone to confirm that hesitation and stumbling at WOT could be caused by running too rich.
Any other ideas or suggestions?
Old Dec 16, 2002 | 10:30 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Anyone else??
Old Dec 17, 2002 | 04:57 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Did you check your fuel pressure?
Make sure you dont have any vacume leaks and that all your plugs and plug wires are ok! Sometimes you can have a miss and not feel it until you really get into it!
Old Dec 17, 2002 | 06:17 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Fuel pressure is fine now that I have the Racetronix set up.
Note that I have excellent response and accelleration till about 97% WOT. At full it goes to sh t.
I am thinking that it is too rich with the 23# injectors and I need to program a new chip to compensate.
Just wanted some experiences on running too rich at WOT and seeing if others have had this problem
Looks like just me.
Old Dec 17, 2002 | 07:29 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Dead spot in TPS? Its cheap....change it and see.......
Old Dec 17, 2002 | 07:48 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Good suggestions. Please keep them coming.
But in reply to your suggestion. I checked the TPS with my autoxray scan tool. TPS volts increase smoothly throughout position of throttle.
Old Dec 18, 2002 | 12:45 AM
87_TA's Avatar
I read your post but you need to understand that it is not very common to get a rich misfire unless your ignition system is to weak or your plug gap is too big.
Make a wot pass and turn off car while in WOT and pull a plug.
Is it very black and wet?
The TPS is a good place to check also like mentioned ,what is voltage showing at WOT?
have you ever checked fuel pressure at WOT while this occurs?
What your base timing set at? whats your scan tool showing
under WOT spark adv?
Old Dec 18, 2002 | 06:50 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Thanks for the ideas. I will do some runs and look at these things.
Will update after I get the information.
Old Dec 18, 2002 | 08:22 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Here are some values from a previous run.
TPS volts at WOT = 4.27 V
Base Timing = 16.8 deg
WOT Spark Adv. = 22.7 deg w/ 1 deg knock retard
BLM = 128
INT = 128
MAP = 4.76 V
O2 Sensor = 876 mv
Fuel Pressure at 50 psi w/ stock failing pump
My fuel pump was going out as the fuel pressure would drop at WOT. I thought this was the problem, but it still does it with the new high flow pump, hot wire kit, and fuel filter????
Does this tell you anything???
Looks OK to me???
Old Dec 19, 2002 | 07:27 AM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
Man you are running a pretty high FP!! I think I would have tuned that sucker from like 45 or a little lower!
I guess everything looks ok from here, but we would really need to see the scan file and or an export from it!
Old Dec 19, 2002 | 05:29 PM
88GTA3555SPD's Avatar
Car: 88GTA
Engine: 383
Transmission: t5 junk
his fuel pressure isnt high at all especially with a high flow pump to support it....stock is alittle over 40.....i got mine set at 55 with the stock injectors and the car performs amazingly....w/sportsman2heads and 502/510 lift 224/230cam, 1.6 rockers, 52mm t.b.,shortys to a 3 inch catback slp runners
unfortunatly with a stock chip
Old Dec 19, 2002 | 07:53 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Actually I am running 40 psi now with my new high pressure Walbro pump and still have the same stumbling/hesitation problem.
I also have a periodic problem with the idle just dying off till the engine kills. But if I start it and give her some pedal (not WOT) the car just takes right off with no hesitation???
I am really thinking that my WOT tables need to be modified with my current set up.
Also my idle tables.
I will post the AutoXray files shortly.
Thanks.
Old Dec 20, 2002 | 12:09 PM
mypontiac's Avatar
Car: 1991 Conv. TA
I have some new observations with the hesitation and stumbling problem.
I found that if I am in second gear and gradually increase the pedal angle before going into WOT then the problem does not occur. So what is happening is that I am not going into WOT untill I am at about 4000 RPM.
So what it is looking like is that by going WOT at too low of an RPM then I am putting too much fuel in then what is needed and causing the engine to stumble. By waiting till the higher RPM to go into WOT, the rich fuel mixture can be tolerated better and does not cause the problem.
So it looks like if I change the injector constant to produce less fuel the problem my be solved.
Opinions?
Old Dec 21, 2002 | 03:49 AM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
Maybe take some fuel out of the VE tables!
Old Dec 21, 2002 | 05:02 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Yes. I think I will go that route and see what happens.
I am going to install my supercharger over the holidays and will begin tuning after that.
I am sure that this will open another can of worms.
Old Dec 21, 2002 | 11:46 PM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
I would suggest fixing the problem you have before you proceed with the blower install!
Old Dec 22, 2002 | 12:42 AM
funstick's Avatar
just a thought here whats the wot a/f ratio at ? or more correctly how the PE vs RPM table filled out. with stock injector they might have hads to push it up to very rich in a/f calculation term. but with more fuel flow that could be way to much fuel.
Old Dec 22, 2002 | 01:02 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Exactly Funstick.
That is why I am going to see what happens with the SC install. It may be that the higher air flow from the SC will fix the rich problem I am having now with normal aspiration.
I appreciate your comments Poorboy8. I will just test drive it with the sc on to see if the problem persists. If so, I can remove the drive belt and tune from there.
But I suspect that the entire problem is from a rich condition caused by the upgrades as recommended for the sc and still running normal aspiration.
I will update. Got the parts layed out as we speak.
Old Dec 22, 2002 | 02:19 PM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
I still stand by what I say.....I guess I just figure it's better to try and fix the problem before you go adding another potential one
On the other hand I agree with funstick and think that the blower will definately want more fuel.
Definately keep us up to date, I'm interested in seeing what happens!
Old Dec 22, 2002 | 04:04 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Thanks for the support. I will be cautious.
I am installing a kit that was custom made for list member Willie.
Am running though some trial and error fitting the intercooler tubing right now. Cut one of the Damn hoses too short so I need to try to find a local replacement.
Fun though.
Am excited to see the outcome. Looking for a 400 HP little 305!!!
Keep you posted.
Also see the post under power added named twin intercooler started by Willie.
Old Dec 22, 2002 | 10:41 PM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
yeah I remember you from over there, I've been one of the guys WAITING for the out come of this setup, because I have been toying with the idea of a blower sometime soon maybe!
Old Jan 27, 2003 | 10:19 PM
mypontiac's Avatar
Car: 1991 Conv. TA
I have been working with a PROM programmer from www.pcmforless.com
His name is Alvin and he is very familar with the programming of our 3rd gen cars. :hail:
He initially took the modifications information done on the car and sent me a first run prom. I provided him (through email) data using TTS software collected with my laptop. He then reprogrammed the prom file and sent it to me via email. I burned the program into the prom using pocket programmer II.
We went through this process about 6 times. But now I have a prom that gives the car perfect start up idle, very sensitive accelleration and incredible power at WOT!!!
I highly recommend his services. He is friendly and motivated.
We exchanged files this last weekend. He would take less than an hour to send me a new prom file from the time I sent the data.
Hope this helps other list members.
Old Jan 28, 2003 | 01:24 AM
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
Wow that is great, although I dont understand why you wouldnt just go ahead and get the Tuner cat software and start doing some programming on your own. It sounds like you have everything except tuner cat and or winbin or whatever.
Old Jan 28, 2003 | 10:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Would you happen to know what the fix was for your initial problem? The hesitation and stumbling at WOT. Was it what you were thinking, too rich?
RBob.
Old Jan 30, 2003 | 04:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
ttt
Old Jan 30, 2003 | 09:26 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Yes I believe it was the problem. Once I added the supercharger and gave it more air the problem is gone.
I do plan on learning how to program my own chips that is why I bought the pocket programmer. But since the car is my daily driver, I wanted to get it tuned right away.
This was actually a good first experience. Although I did not create the program, I went throught all of the other steps. As of collecting data and burning the prom. Fun stuff!
Old Jan 31, 2003 | 10:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK thanks for the update. Nothig wrong with taking the ECM programming/tuning stuff one step at a time. Can be overwhelming otherwise.
Are you planning to go with a 2 bar MAP & some boosted code? (IE: $58).
RBob.
Old Jan 31, 2003 | 11:33 AM
mypontiac's Avatar
Car: 1991 Conv. TA
Yea. But I need to read up on it.
Do you know of any good tech sources or threads?
Thanks.
Old Jan 31, 2003 | 02:09 PM
Gary Anderson's Avatar
RBob,
Pardon my ignorance, but the $58 code is Turbo Grand Prix (6 cyl) correct? Does this mean that if you change the cylinder select it will run a V8? I've been wondering about that for a while. Somehow I didn't think it would work with spark advance being calculated with a 90* in the formula somewhere. Again maybe it's just my inexperience but don't V6's fire on 60* intervals?
I'm not questioning you, just trying to learn as you are far more advanced with this stuff than I'll ever be. I just wished you used the '730 as that is what I have. I try to adapt your '747 info to my '730 with varying results. Thanks.
Regards,
Gary Anderson
Old Jan 31, 2003 | 03:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks.
I think my post dropped off the face of the earth or something. Try this link:
http://www.diy-efi.org/gmecm/ecm_info/1227749/
Don't miss the P4 doc.
RBob.
Old Jan 31, 2003 | 04:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by Gary Anderson
RBob,
Regards,
Gary Anderson
You guys' have to spend more time wearing out the search feature and the archives.
The TGP is $8F, the $58 mask is SyTy and Sunbird/Grand am.
Most masks handle the differences between 4, 6, & 8 cylinder engines. It is a cal parameter. Some don't calc an airflow term properly (always zero) when set to an 8 cyl.
RBob.
Old Jan 31, 2003 | 05:25 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Thanks RBob,
Now I got some good reading to do.
What kind of projects do you have going???
Old Jan 31, 2003 | 06:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks RBob,
LOL, projects? Way too many. The short list is I'm halfway to having the Elky w/EFI. Running a '747 for ignition w/carb at the moment. Fuel return line is in, surge tank built. Have another (fresh) engine waiting for warmer weather with a TBI on top. Gonna' use the old carb for a flower pot!
Helping someone else out with an EFI conversion on a '68. First was going to be TBI, then LT1 intake, now he is going with a port injected Torker intake & '727. Heck, he's doing the mechanicals, so doesn't matter to me. Once he bolts something on top I'll do the ECM side .
With winter having set in here I've been busy with code, that and school. Inside stuff. As they say, getting ready for the spring thaw.
RBob.
Old Jan 31, 2003 | 06:44 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Hec. I just came from outside to install the latest chip I burned new code to!
I am in Louisiana. It gets cold here. But cold for us is 30's !!!
Right now it is sweater weather. Winters are mild but summers are brutal!!!
Keep warm.
Nice chatting with ya!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Damon
Sep 26, 2015 04:29 PM
