Where do I find the VE tables
I own Tunercat and definition files 32b for my stock ABWT chip and 6e for the ARAP chip. My fuel pressure is adjusted correct for my injectors, but my BLM's are still high (lean). I have been told I need to adjust the upper and lower VE tables to achieve 128. The tables I was told to look for are labeled something like...
"VE vs. RPM vs. MAP kpa"
However I have been unable to fine any table labeled like this in my definition files.
Next:
Do I need to record my BLM value at different fuel cell numbers, then make the corrections in the tables? The formula given to me to use...
BLM reading/128 X Fuel Cell #
Then to modify the corresponding table.
Next:
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
That's because your car is MAF. MAF cars don't have VE tables. You were misinformed. Only Speed Density cars have VE tables. Welcome to MAF
Tim
Tim
Tim,
Tunercat wrote back and said the same thing, they said all I can do is to set my injector constant and then adjust the following table...
"BPW vs. Load vs. RPM"
To acheive BLM's of 128. Maybe you can answer this question, is it desired or possible to maintain 128 from idle up to 4000 rpm's?
mine seem to mutate from 126-132. i cant seem to get them at 128 all the time. if at 128 after data log. next datalog seems to move a bit on its own. i assume temp of environment plays a role. close enough.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 91 Red Sled
that (MY) post was a screwup. i did not intend to post there. POI is that with XRam they would swing (mutate) more often that with Holley Projection. when i pulled plugs on Xram they were 4 perfect and 4 rich. that was a year ago when i swapped manifolds. the Holley unit appears to have the disribution issues covered and BLMs report more consistent. i did see them all swing fron 126-130 up to 136 with a environmental rtemp change of 20 degs F. i am running OL and that did not help my tune!
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: Where do I find the VE tables
i'm reading up on all 12 posts i can find related to the ABWT bin, and 32b. i saw what jprevost posted as far as jump settings on blms and int, looking in my xdf i have no such settings, is this an adjustment made in the raw hex and what is it? my fueling is almost this close but my int is jumpy as expected on a maf car, this change would be good i think.
reading is good by the way, took me a week to figure out that all the 32b temps are in celsius not f*.
86CamaroDan
Sep 29, 2015 10:08 PM
