Does %TPS need to be changed with a 52mm throttle body?
Old May 20, 2003 | 07:24 PM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
I am having trouble with TC lockup since changing to a 52mm throttle body. Could this be because more air is flowing at a lower tps than the stock 48mm? Would lowering the TCC enable threshold solve this? I'm using the ARAP bin in a L98 Superram with about 300 rwhp.
Old May 21, 2003 | 07:58 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I don't really understand the question. Of course you can change TCC parameters to suit how you drive though.
Old May 21, 2003 | 08:30 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Different than what it should be ? The answer is no.... The answer to the question could be yes if it isn't set correctly. When I installed my Holley 52mm Throttlebody it was ness. for me to modify my TPS to fit the throttle body correctly. If I wouldn't have it wouldn't of operated correctly and voltages would have been incorrect.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
