1227730_8d.ecu
Old Jun 9, 2003 | 06:53 PM
tpi_roc's Avatar
1227730_8d.ecu
Code:
/*Item 113: Lambda C */
/*startAddr				=617,
/*columns				=17,
/*rows				=1,
/*elementSize			=1,
/*bitMask				=0,
/*offset				=0,
/*mulOrDivOrBit			=1,
/*factor				=128,
/*map_name				=Lambda W vs RPM (AFR = LAMBDA C + LAMBDA W),
/*ylabel				=,
/*yaxis				=,
/*xlabel				=,
/*xaxis				=,,
Does anybody have the x axis corrections so I know what RPM I'm tuning at?
Old Jun 9, 2003 | 07:35 PM
tpi_roc's Avatar
I may have fixed it, can someone verify, I have changed it to:
Code:
/*startAddr				=617,
/*columns				=17,
/*rows				=1,
/*elementSize			=1,
/*bitMask				=0,
/*offset				=0,
/*mulOrDivOrBit			=1,
/*factor				=128,
/*ylabel				=,
/*yaxis				=,
/*xlabel				=RPM x 1k,
/*xaxis				=.00.40.801.21.62.02.42.83.23.64.04.44.85.25.66.06.4,,
Can someone verify that the RPM's are right ?
Old Jun 9, 2003 | 07:37 PM
tpi_roc's Avatar
Or this:
Old Jun 9, 2003 | 07:47 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
; LAMBDA W RPM
L8617: FCB 113 ; 0.941 0
FCB 113 ; 0.941 400
FCB 113 ; 0.941 800
FCB 113 ; 0.941 1200
FCB 115 ; 0.949 1600
FCB 115 ; 0.949 2000
FCB 115 ; 0.949 2400
FCB 137 ; 1.035 2800
FCB 128 ; 1.000 3200
FCB 160 ; 1.125 3600
FCB 150 ; 1.086 4000
FCB 157 ; 1.113 4400
FCB 138 ; 1.039 4800
FCB 138 ; 1.039 5200
FCB 138 ; 1.039 5600
FCB 138 ; 1.039 6000
FCB 138 ; 1.039 6400
Old Jun 9, 2003 | 07:51 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
For what its worth..
Old Jun 9, 2003 | 09:11 PM
tpi_roc's Avatar
Thanks guys looks like i got it squared away
In case anybody needs an .ecu with this corrected lemme know
Old Jun 9, 2003 | 11:39 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If you dont mind email me one.......
thx/N.
Old Jun 9, 2003 | 11:44 PM
tpi_roc's Avatar
Well in the effort to email one person I decided to just host it
so here ya go
730.ecu
Old Jun 9, 2003 | 11:47 PM
tpi_roc's Avatar
Note: right click, save target as
Otherwise you'll just view the code
Old Jun 10, 2003 | 07:13 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Hmmm... this is what i got when I tried using it, I'm I doing something wrong?
Old Jun 10, 2003 | 10:20 AM
tpi_roc's Avatar
Ok this is a modified ecu from the gmecm site, I "corrected"(?) the power enrichment table to reflect the same way. Let me know if this takes care of it, remember the table with this ECU you'll be looking for is simply "Power Enrichment"
7730v3.ecu
Old Jun 10, 2003 | 10:47 AM
tpi_roc's Avatar
Here is another 730 ecu file from http:///gmecmedit.markmansur.com, I fixed the PE vs RPM table again, this one works in winbin and gmecm both, the table label is:
1227730-8dm.ecu
Old Jun 13, 2003 | 12:06 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Now it works, thanks.
I have another questions about the 730.ecu files, I've been reading about tuning the 730 and there should be a cylinder size constant but I can find it in any of the *.ecu files I've found. Is it in TC only?
Anyone have a "complete" *.ecu file for the 730?
(preparing for a 730 swap as soon as my memcal arrives....)
/ N.
Old Jun 13, 2003 | 09:51 AM
tpi_roc's Avatar
Its called "Speed density calc" in these .ecu's
Hope that helps
Old Jun 21, 2003 | 05:20 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I just found the calculations to show how you get the 159 value... See https://www.thirdgen.org/techbb2/sho...threadid=38912
Old Jun 25, 2003 | 07:19 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
.ecu files same for all tuner programs??
I just bought a PROM burner and am going to get into tuning, but am wondering if .ecu files work on ANY tuner - tunercat, winbin, etc.
Thanks!
Old Jun 25, 2003 | 08:20 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
.ECU files work with WinBin and GMECM, but not Tunercat, which has its own format.
