convert LV8 to Kpa MAP
Old Jun 17, 2003 | 06:22 AM
devilfish's Avatar
I got a spark tabel from a LV8 car that I whant to put in my MAP car. Can I just print them in?
Old Jun 17, 2003 | 06:42 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: convert LV8 to Kpa MAP
If you use due care.
When starting out on doing a spark table I always take a few degrees out at the higher load points, and then gradually add them back in, once I see the motor's not detonating, and it's behaving. If it varies much from what the oem file for your engine you might just do the under 2,500 rpm area, and then add another 1K RPM after you test drive that, and build on it like that. It's easy to go in small steps and proceed with caution, then make a wholesale change and then try to figure out what went wrong.
Old Jun 17, 2003 | 08:30 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Devilfish.... If you like email me the spark table for the LT4 cam it could be "fun" to have.........
My SD stuff is on the way...soon I'll be tuning SD too......
jamieriplilb
Exterior Parts for Sale
Oct 28, 2016 10:30 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
customblackbird
Oct 1, 2015 04:30 PM
ULTM8Z
Sep 16, 2015 09:15 AM
89fast5oh
Sep 8, 2015 09:55 AM
