car not starting after PROM is removed...help
Subscribe
Jun 27, 2003 | 09:36 PM
I've had this problem before and Ive finally narrowed down the cause. Whenever I remove the chip, after I put it back in the car won't start. Like last night for instance. Car has been running fine for a week now. I decided to change the chip b/c I had made some changes. Well, I pull it out and put the new one in and it won't start. So I put the first one back in and still nothing. It cranks and cranks and cranks but no start. Why?
Reply 0
Jun 28, 2003 | 01:28 PM
On your changes did you disable VATS?
Make sure all the pis are making contact in the ZIF socket.
Are you even using a ZIF socket?
Reply 0
Jun 28, 2003 | 03:18 PM
Yes, the VATS is turned off. I'm using the Craig Moates adapter/ZIF socket too so I'm pretty sure that's all good. Like I said, the only thing I did was pull one chip and put another in. Nothing else. I even tried disconnecting the battery to clear the memory. Any ideas?
Reply 0
Jun 29, 2003 | 05:30 AM
Are you sure you are putting prom back in right direction?
Start trouble shooting, Is fuel pump coming on?
do you have spark? Are inj. pulsing?
Reply 0
Jun 29, 2003 | 11:58 AM
Are you saying you didn't disconnect the battery BEFORE you put it in? I could be wrong...but I think that is a major no-no
Reply 0
Jun 29, 2003 | 01:37 PM
No thats not a problem at all.
Reply 0
Jun 30, 2003 | 07:34 AM
Got it fixed. That wasn't the problem. Just a coincidence that made be belive that it was. Thanx for the help.
Reply 0
Jun 30, 2003 | 07:39 AM
WHAT was the problem???????
Give us the scoop, please!
Reply 0
Jul 1, 2003 | 07:28 AM
I honestly have no idea . I went out on Sunday to work on it and the battery was dead, so I jump started it and it fired up after a little convincing. I guess after all the PROM changes the computer was so confused that it took the battery to go completely dead to clear the memory. I dunno I' m just glad that it runs now.
Reply 0
Jul 3, 2003 | 02:23 PM
Me too. Glad it's ok now.
These things sure can me temperamental sometimes.
Reply 0
Jul 3, 2003 | 08:42 PM
Yes, and very frustrating. Since the incident I've swapped the chip numerous times with no ill effect. I don't know what was up!
Reply 0
Subscribe
