Spark table question
Old Jul 13, 2003 | 01:29 AM
TORC's Avatar
I've just put a TBI system (1227747) on a non-GM engine and have a question about the main spark table. I've got the engine running on the AHRT bin file. The engine I'm working on is an International Harvester 345. I've been told that these engines like a little bit more timing than a SBC 350. Looking in the factory service manual for the IH engine, I was able to generate a curve for the mechanical and vacuum advance from the distributor test data points. I then took these two curves and combined them to make a spark table.
Here's the AHRT's spark table followed by the IH spark table:
Code:
30 30 30 30 30 26 23 19 16 14 10  8  7  6  5
30 30 30 30 30 26 23 19 16 14 12 10  7  6  5
30 30 30 30 30 26 24 20 19 15 13 11  9  8  6
30 30 30 30 30 26 25 23 20 17 15 13 10  9  9
30 30 30 30 30 28 26 24 21 19 16 14 13 12 12
30 30 30 30 30 28 27 25 21 20 18 16 15 14 14
31 31 31 31 31 29 28 26 23 21 20 18 16 15 15
31 31 31 31 31 30 29 27 24 22 21 20 18 17 16
32 32 32 32 32 31 30 28 25 24 22 21 19 18 17
32 32 32 32 32 31 30 28 26 25 23 22 20 19 18
33 33 33 33 33 32 31 28 26 24 23 22 21 20 19
35 35 35 35 35 33 32 29 27 25 24 23 22 21 20
36 36 36 36 36 34 33 32 28 27 26 24 23 22 21
37 37 37 37 37 36 33 32 31 29 28 26 25 24 23
10 10 10 10 10 10  9  8  7  6  2  0  0  0  0
14 14 14 14 14 14 13 12 11 10  6  4  4  4  4
17 17 17 17 17 16 16 15 14 12  9  7  7  7  7
20 20 20 20 20 19 18 18 17 15 11 10 10 10 10
22 22 22 22 22 22 21 20 19 18 14 12 12 12 12
25 25 25 25 25 24 23 23 22 20 16 15 15 15 15
27 27 27 27 27 27 26 25 24 23 19 17 17 17 17
29 29 29 29 29 29 28 27 26 25 21 19 19 19 19
32 32 32 32 32 31 30 30 29 27 23 22 22 22 22
35 35 35 35 35 35 34 33 32 31 27 25 25 25 25
38 38 38 38 38 37 36 36 35 33 29 28 28 28 28
40 40 40 40 40 39 38 38 37 35 31 30 30 30 30
I can see that there is a little more advance on the upper end of the table, but what puzzles me is the upper left portion of the tables. The AHRT table stays way up in the high 20's an 30's where the IH table drops way down to almost single digits.
So, I guess my question has to do with how the ECM handles the spark data. Is there more timing in the tables because of the algorithm used to calculate the final spark value? I'm a bit more than a little confused here. I'm also not ruling out the possibility that my generated table is total crap.
Old Jul 13, 2003 | 05:31 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
When all you have are weights and a vac chamber, compared to electronics, the best you can do is crude, with the mechanical stuff.
Looks like the IH has large chambers, and/or low CR, and not much swirl/tubulence.
You can't get the engine to 90 K/Pa at 1,200 under normal operating conditions, so it's rather mote what goes on up there, other then when your doing a burnout, and lift quick and the engine goes thru there if it starts to stall.
Old Jul 13, 2003 | 09:00 AM
TORC's Avatar
Yeah, it is kinda low compression. Bore is 3 7/8" and stroke is 3 21/32". CR is 8.28:1. It's a HEAVY slow revving truck engine. Everything in the recip. assembly is massive so it revs real slow but has a lot of inertia. The engine with standard accessories weighs in at 727 lbs.
In your opinion, should I use the Chevy table and modify it or use the table based on the IH data and see what happens?
Old Jul 13, 2003 | 09:57 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I'd split the difference, and just use an average to start with. She'll tell ya what she likes once you start playing with it.
Old Jul 13, 2003 | 10:55 AM
TORC's Avatar
Thanks... I've got it running but still have couple more things I need to do before it's road ready. Once I get it driveable and I can start logging data, I'll start playing with it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
