Using ARAP code with a Supercharger...
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Some say that the MAF tables in the ARAP code are superior than other versions found in 1227165 ecms, so my question is, would if be safe to try running an ARAP chip with a Supercharger installed in the car?
Of course I have copied the spark tables from my original ANYJ code because running the stock ARAP spark tables would kill the engine in no time at all, but are there any other pitfalls that I need to be aware of?
Originally posted by anesthes
Under full boost your gonna be in WOT land. Most of your maf table is useless under boost.
-- Joe
-- Joe
Thats why I want to know if I am safe by using the spark tables from my original ANYJ code.....
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Your safe using the maf + even some of the spark. Tuning $8D always kinda pissed me off with the blower, though.
At one point tpi_roc made a arap bin importing aujn timing. Didn't work very good on a stick though.
-- Joe
-- Joe
Car: Death Mobile
Engine: 666 c.i.
Originally posted by funstick
all lies the maf tables are the same across all 165 ecms that use maf.
ZaphodB, do a Binary Compare of a variety of $6E bins on the various MAF Scalar Tables if you wish to see the differences. In fact, try a couple.
FYI, I HAVE tested the various MAF Scalar Tables from various $6E bins on a number of 1989 MAF cars (with different engine combos). The ARAP consistently came the closest to giving 128/128 in part throttle driving under various conditions.
I also found the spark tables were too aggressive and needed to be toned down.
Sean, your blanket statement is misleading. The value entries withing the various MAF Scalar tables for the ARAP are different. It works the same as other $6E, but the values are different than other $6E values.
i think your over reading the issue. the transfer function of all the MAF 165 and 870 ecms is the same. they use the same sensor calibrated in the same manor. the issue you are reffering to is the way in which they handle for FPR correction by changing the scallers in which they define the transfer function values table to table. its a farse however considering that the basic element of the table will always have to be either the same or extremly close. there is nothing special about $6e or arap for that matter aside from pe fuel and the vettes aluminum heads wanting more spark. start comparing the actually transfer function values of each code from code to code. they are all pretty much the same.
So I'd agree with you on that, MAF tables in ARAP are better, although I still have some more work to do.
Car: Death Mobile
Engine: 666 c.i.
Inspite of what some individuals claim, I never said "You CANNOT adjust the MAF tables". I've always said that using the ARAP Bin comes the closest with the LEAST amount of tweaking require necessary.
This is ALL for part throttle. Once you get into boost and max the MAF, you then enter new tuning issues. If you are not in PE yet the boost is maxing the MAF (a distict possibility), you then have some challenges to tuning. The O2 sensor will compensate, but don't be surprised if your BLMs go lean. This is why many guys use an FMU.
When in PE, you can use the PE tables to add the extra fuel needed. In fact, you may find it preferable to engage PE sooner to avoid the part-throttle/max MAF/lean O2 reading.
