MAF Power Enrichment Tables are -
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
This is a "custom" burned chip for a miniram w/ stock heads/LT4 cam...... and I'm using it as the basis to start tuning for the higher rpms of my Stealth Ram/Pro Heads/Comp XE262. The PE tables are very different than others I've seen. Here they are:
PE vs TMP
Deg F---%
306------22.66
262------22.66
219------22.66
176------22.66
133------22.66
46--------33.59
8----------43.75
PE vs RPM
0 400---------- (blank)
Blank-----------(-18.75)
6400-----------(-18.75)
6000-----------(-18.75)
5600-----------(-18.75)
5200-----------(-18.75)
4800-----------(-18.75)
4400-----------(-8.60)
4000-----------(-8.60)
3600-----------(-0.00)
3200-----------(-0.00)
ent-------------(11.72)
richm-----------(11.72)
nt En-----------(11.72)
Perce-----------(11.72)
Why are all the PE vs RPm in negatives? I would think that you'd want a posative number to add such and such a percet to the fuel? Maybe I have it backwards? I want to know what way to go to add more fuel up high.
Car should be much faster than it is. This is one of the things I need to know about.
Thanks guys!
-Paul
PE vs TMP
Deg F---%
306------22.66
262------22.66
219------22.66
176------22.66
133------22.66
46--------33.59
8----------43.75
PE vs RPM
Thanks guys!
-Paul
I'm confused! No one knows which way to turn the tables?
I have to turn my fuel pressure up to 46psi with 24lb injectors to keep from getting a lean pop or two when I step on the gas. This peggs my blms to 112 all the time and sucks the gas milage.
Although at WOT my o2 mv are 920-1000 so I'm not too overly rich at WOT so I need to back the pressure down till my cruise BLMs are 128 ish and then add gas to the enrichments to get rid of the lean pop.
I know how to use the AE but not the PE. HELP!?
All the negative numbers are doing is counteracting the PE vs Coolant temp F/A adder.
Right now reducing that negative number will add fuel until you reach zero then use positive #'s to add.
Notice the tables are richer where peak torque peak should be around. IE: -00
sailtexas186548
08-24-2015 10:11 PM
