Anyone need a romulator
Old Sep 24, 2003 | 11:17 AM
rooster433's Avatar
Selling mine cause i can't get it to work on my 93 Firebird... works good on everything else..
Guess theres just a compatablity issue
$145 obo????
Old Sep 24, 2003 | 02:00 PM
yellow73bb's Avatar
Do you have a socket problem on the ECM? The romulator should work in any ECM, there is nothing magic about any of them as far as I know. Have you contacted the guys at xtronix about it?
After using mine with TunerCAT RT, I don't know how I could live without one anymore.
Old Sep 24, 2003 | 02:48 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Anyone need a romulator
$145 obo????
Have you talked to George?.
Not Karl or the Gal answering the phone.
If so what did he say.
Old Sep 24, 2003 | 04:33 PM
rooster433's Avatar
they had no idea, told me to talk to tunercat... tunercat says the same thing..
Remeber i had a post asking if anyone else coudl get it to work. I know the units not bad cause it works for everything else i try it on.
Tired of messing with it really. ON the 93.. if the chip isn't right it sometimes does really funky things like pulse the injectors with out the motor running.. It did this when i was testing a switcher adatper for craig and sometimes when i play with the RT... it sucks because the time it did it with craigs adapter bythe time i went to start the car there was so much fuel in the motor it hydrolocked and broke the nose off the starter.
I guess maybe the 93's have a speed issue or something, maybe the long ribbon isn't fast enough (would sorta explain why the switcher adater doesn't work either)
Old Sep 24, 2003 | 05:17 PM
yellow73bb's Avatar
Sounds like it could be a ground problem, have you checked the ground cable from the engine to the frame or firewall? There are a couple of grounds from the ECM too. I don't think your ECM should ever fire the injectors without getting a signal from the distributor. That would be a serious safety concern to the lawyers at GM, and they would have issued a safety recall long ago if it were a common problem.
Old Sep 24, 2003 | 05:19 PM
rooster433's Avatar
its fine with a normal chip................
Comon, anyone want this thing?
Old Sep 24, 2003 | 06:47 PM
funstick's Avatar
im interested in aquiring another one. and the lt1 pcms seem to dislike romulators from what i can tell so far. nobodys knows why as far as ive heard. proboaly more of the same type of BS with the P4 pcms.
Old Sep 25, 2003 | 11:20 AM
epkid's Avatar
Any takers yet. Rooster, check your pm.
Chad
Sp0nGa
Feb 16, 2009 02:36 PM
JPrevost
Sep 13, 2005 03:51 PM
brennanw
24
Jun 8, 2004 08:22 PM
Swapmaster
Sep 4, 2003 10:15 PM
3.8TransAM
May 18, 2003 09:12 PM
