B&M Megashifter Relay (To buy or not to buy)
Old Oct 15, 2003 | 08:49 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Bought the B&M Megashifter... and they say that I have to buy a relay from radio shack that reconnects the circuit which:
With the factory shifter the orange and black wires are switched together in the Neutral and Park positions. This circuit locks out the converter clutch, and changes the idle speed.
Basically if I don't get the relay, the computer is going to think I'm in gear all the time... and when I actually DO shift into gear.... what happens?
Is this something I can just tune for in the my chip and call it good rather than go HOPE radio shack has the part?
Thanks Guys!
Old Oct 15, 2003 | 10:08 PM
Kandied91z's Avatar
they had the part on the shelf 2 years ago when i put mine in. i bought two just in case.
i actually made my own harness though so i wouldn't have to cut up the factory piece just in case. this of course was the most time consuming.
Old Oct 16, 2003 | 06:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The engine may stall when placed into drive. I'd say to try it and see how bad it is. If there is a stalling problem then do the relay install.
RBob.
Old Oct 16, 2003 | 07:31 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
FWIW, I ran without the relay for a long time and it didn't matter except in my mind. I couldn't mentally deal with the fact that the ECM didn't know I was in Park vs. Drive so I installed the relay.
Tim
Old Oct 16, 2003 | 11:25 PM
My engine stalls if I put it in drive as it sits now... unless I let it idle for about 30seconds (And this is warm!)
Thanks guys, I went ahead and installed the relay. It was easy.
Old Oct 17, 2003 | 10:57 PM
Larry's Avatar
Car: 86 Corvette
I don't have the P/N wire hooked to anything and don't have any problems since I "downgraded" back to factory a/c delco ingition module and coil.
BumpaD82
Feb 26, 2016 02:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
