Stealth Ram Bin
Old Nov 8, 2003 | 02:45 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Stealth Ram Bin
In the process of putting this thing on my Vette. Does anyone have a bin that I can start tuning it with? Kind of a base line.
I noticed that the holley adj fp reg is not vacuum controlled so I'm definately gonna have to tune cruise mode!
Anything is appreciated.
John
Old Nov 8, 2003 | 03:01 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Stealth Ram Bin
I was thinking of getting this intake, is there any downside to not having it vacuum controlled, anyone?
Old Nov 8, 2003 | 03:43 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
The only down side is that the tpi fuel regulator uses vacuum to reduce fuel pressure at idle and light-mid throttle. The holley doesn't. So idle and mid range will be at the same pressure as wot. It is the same as running your present set up with the fp regulator vacuum line disconnected. It will run rich at idle and part throttle so some tuning will more than likely be required. I don't know for sure how much because I haven't installed it yet.
I know there are some folks on here running it so I figured I throw the question out there.
It is definately a kick a$$ set up though!
John
Old Nov 8, 2003 | 03:57 PM
clippjr8's Avatar
the adj. fuel pressure reg on the holley stealth ram is vaccum controlled. the vaccum hose comes off the back of the intake and connects over the adjuster on the AFPR. i have a bin you can start with but use it at your own risk. it is the one i use with vette ported heads and the zz-9 cam and it runs great for me. email me if you want it.
Old Nov 8, 2003 | 08:48 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Yes, both available hsr regulators, adj. and non-adj., are vaccum controled.
Old Nov 9, 2003 | 11:42 AM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: Stealth Ram Bin
Hmm? I have a holley adjustable FPR on my vette and its vaccum controlled for sure.
Old Nov 9, 2003 | 01:06 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
Thanks for the replies guys!
Well I only gave it a quick look but I'm glad it is vacuum controlled.
This will make it easier to to tune. Thanks again!
John
Old Nov 12, 2003 | 10:37 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I notice you have an 89 Vette which means it runs MAF.
I did some tuning on a Stealth Ram on a ZZ4 and found it was very close to a Miniram on a ZZ4. This is on a SD setup where the stock bin needed to be modified (VE Tables) to run right.
However, on a Miniram with a ZZ4 that had MAF, the stock MAF bin worked very well with only some minor changes (injector size, turn off EGR, optimize spark and some tweaking with PE Fuel....which was probably off anyway).
But you should be able to use your stock bin with only minor changes (injector size and EGR) to start, and then just optimize the spark and PE fuel at your convienence.
Old Nov 13, 2003 | 07:12 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I had to add a bunch of AE fuel to get the car moving and not give me a violent lean POP.
I started with the ARAP bin turning off EGR, chaning my injector constant, and then playing with AE and PE.
Don't know why, but the car hated highway mode... it would throw me a SES light and the car would hop around when i entered that mode... so I had to turn it off.
Old Nov 13, 2003 | 07:35 PM
Car: Death Mobile
Engine: 666 c.i.
While I like the MAF Scalar tables of the ARAP bin, I don't like the spark tables. Too aggressive. Combine that with the extra spark of the highway mode and I think the spark advance is too much.
This may be what you encountered.
Old Nov 13, 2003 | 08:13 PM
That is possible. Since then I made my own spark table and drastically lowered the cruise timing. Maybe I'll try highway mode again.
Good call, thanks
Old Jan 11, 2004 | 01:00 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
What were some of the major changes that you had to make to get the SD setup to work? I've been having backfiring issues w/ mine, some out ot the exhaust and others thru the intake. It didn't do it w/ the old motor. Now the new heads an intake are on, the thing doesn't get out of its own way.
Old Jan 13, 2004 | 07:09 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
ttt
Old Jan 18, 2004 | 12:31 AM
for me i mainly needed to add more Acceleration enrichment to get mine to move.
Most of my backfiring was lean pops through the intake.
And I'm Maf.
Old Jan 19, 2004 | 06:16 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
And I'm Maf.
A friend and I already added some to the accel. enrichment. It seemed to help but didn't completely get rid of the pops. Did you have to add a large amount?
Old Jan 19, 2004 | 06:38 PM
Almost double in my Acceleration Enrichment VS LV8 table.
The Stealth Ram has a larger plenum than TPI, and I've learned and listented to Grumpy that a larger plenum volume needs more AE for the lower Delta LV8s.
Watch your O2 readings, if you hit the gas and they spike lean (low mv) then you need more and sooner. Also go to the tables section and change the AE enable from 20delta lv8 to 15, and delta tps enable to like 3.2
Old Jan 20, 2004 | 10:12 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Thanks. I'll give it a shot. I guess I just need to add more. I'm new at this so I tend to be a little conservative.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
