VE table and VE table (ext)
Old Jan 20, 2004 | 09:46 PM
ULTM8Z's Avatar
How does the 7730 ECM transition between these two tables (at 1600 rpm) during operation?
The reason I ask is that at about that RPM, there's a really strange stumble. Is there something I should do at that RPM in the tables to get a smoother transition?
Old Jan 21, 2004 | 07:51 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
1600 rpms in the lower table and 1600 rpms in the upper table should be identical. This is true for both fueling and spark. Make sure they are not different. I've seen situations where these values were different and a 'stumble' was the result.
Tim
Old Jan 21, 2004 | 08:44 AM
ULTM8Z's Avatar
Traxion, thanks. Yeah I took a look at my tables last night and they were indeed different. I'll try it out again tonight and see if the problem is corrected.
It was wierd, when cruising at low speeds, hovering between 1500 and 2000 rpm, the engine would stumble, buck and surge, etc. I think you're probably right in your observation.
BTW, I love your tuning-tech articles. Printed most of them out and did a lot of reading, preparing for when I would solve the idle misfire problem. Now that it's solved, my tuning is progressing very quickly and accurately thanks to your expertise.
Old Jan 21, 2004 | 11:15 PM
11sORbust's Avatar
This "condition" also happens with the maf tables. It would be cool to know why the ecm is stumbling...ya know....like in the code...cough...cough...
Old Jan 22, 2004 | 07:34 AM
TRAXION's Avatar
You could always ... cough ... cough ... open up the code and track it yourself ... cough ... cough ...
lol
Tim
Old Jan 22, 2004 | 08:34 AM
ULTM8Z's Avatar
You guys need some Robitusson or something??
Old Jan 22, 2004 | 09:24 AM
11sORbust's Avatar
Lets just say that I don't have that ability. Besides I don't think the code explains why GM made two tables w/ the same entries..!!?
Old Jan 22, 2004 | 10:13 AM
TRAXION's Avatar
The code never explains WHY GM did certain things. That's left for us to interpret. However, we CAN figure out how it is doing it and in what manner. This may lead to an obvious answer as to why GM chose to do it ... or, it may not. You just never know until you track the code.
Tim
Old Jan 22, 2004 | 10:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The table lookup routines as written will only handle a max of a 17 x 17 3d table and a 17 entry 2d table.
RBob.
Old Jan 22, 2004 | 12:18 PM
11sORbust's Avatar
that's why they spit them up into a table ext, this is what you are saying, right?
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
