Help installing new prom
Old Feb 12, 2004 | 08:05 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
I'm currently dropping in a 350 into my car from a 305 so i got this new prom for the 350, well i took the computer out and i belive i found where to put the chip, but i need to know if there is a special way to take the old one out or if i'm wrong and am sposed to put it somwhere else. please help
Old Feb 12, 2004 | 08:06 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
the chip that is by itself is the new one that i need to put in.
Car: 1986 Trans Am
Engine: 5.7L TPI
Old Feb 12, 2004 | 08:07 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
Car: 1986 Trans Am
Engine: 5.7L TPI
helps if i attach the image
Old Feb 12, 2004 | 08:08 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
Old Feb 12, 2004 | 08:57 PM
clippjr8's Avatar
there are two routes you can go. first, you can order the moates adapter at www.moates.net. It comes with directions and is easy to use. second, you can desolder the chip form the memcal and resolder the new chip in its place. Ive done it, you need to be pretty good at the soldering technique, but its possible to do.
Old Feb 12, 2004 | 08:58 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Go here,
http://moates.net/gmecm/hworder.html
Look at part no. G1.
Your old piece goes onto it, along with the new chip, and then both insert into the blue socket.
using a G1 and a ZIF socket is convenient, and easy.
Old Feb 13, 2004 | 01:30 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
oh cool thanks, so i just plug that into what i already have chips in ? or how does it work
Old Feb 13, 2004 | 07:15 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Click the link provided and explore the site. ;-D
www.moates.net
Old Feb 13, 2004 | 07:45 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
how hard would it be to de-solder and re solder the new chip ?
and its the bigger chip that i de solder right ?
Old Feb 13, 2004 | 07:48 PM
Mangus's Avatar
Transmission: T5WC
double post (bad proxy... baaaaad proxy).
Sorry.
Old Feb 13, 2004 | 07:49 PM
Mangus's Avatar
Transmission: T5WC
Its possible, but actually relatively hard unless you have the exact equipment you need (desolder wick, very fine tip solder iron, and most importantly, patience and finesse).
I wouldn't recommend it. I have moderate soldering experience and still managed to do a little bit of damage to the memcal in the process.
Worse case, you destroy the chip (especially if too much heat is used, which is a natural tendency in a difficult desoldering task).
To me anyway, its worth a few bucks to be able to go back to the totally stock memcal (if I ever have to sell the car [not that i would] ) or if I'm having strange problems and want to pull the ECM/Chip setup out of the equation.
And yes. The larger chip. (I hate to sound like a jerk, but if you have to ask this question at this point, I'd wait on the whole thing and do some more research - its possible to get in over your head).
Old Feb 13, 2004 | 08:01 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
I pretty much new it was the larger chip, but when somthing doesnt look exactly the same I like to ask and double check, just to be absolutely sure, as far as the soldering goes, i wont be doing that then, my hands got no finesse, hehehe, they shake too much. i'm not conserned about damaging the stock chip, i dont plan to sell this car, and the 305 is trashed anyway, it was a junker. soo hrmmm, what would you recomend
Old Feb 13, 2004 | 08:04 PM
Mangus's Avatar
Transmission: T5WC
G1. for piece of mind and to keep from potentially damaging your (required, non-optional) memcal.
my two pence.
Old Feb 13, 2004 | 08:06 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
my two pence.
alrighty, i guess thats the route i'll be taking.. dont really got the cash to spend but i'll find a way
thanks for the help, (ya didnt sound like a jerk btw)
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
