EGR Verdict?
EGR Verdict?
I have put the S_AUJP that Trax has put together in my car and wanted to ask a question that has probably been asked before.
Does the car run better with EGR enabled or disabled? Some say it runs better others worse anyone done some testing on this and have any results?
Just asking cause the S-AUJP CCP bin has the EGR disabled.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Enable it and see how your car likes it. That's the beauty of being able to burn your own chips. You can test out things like that and you know the only difference is that you changed one value.
Give it a shot and find out.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
EGR shouldn't have any effect on performance.. its main function is to lower combustion temperatures while cruising on the highway.
Car: An Ol Buick
Engine: Vsick
Backpressure is enough to open most of them.
Adding hot exhuast gases, raises the manifold temp., and the manifold being hot, heats the air passing thru it.
Car: An Ol Buick
Engine: Vsick
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Disable it and forget it.
I know a lot of you believe what you write but there is no way the egr cools the combustion chambers. I understand your theory that inert gases (burnt already) are being introduced instead of fresh air ( burnable oxygen) whichs lowers the volume of combustible material in each cylinder.
BUT here is the problem with this theory, those inert gases that are being introduced are at exhaust gas temperature, a heck of a difference from cool fresh air.
I don't want or need my engine to have to ingest hot air, cool, denser air makes power, hot exhaust gases will hurt performance. I also do not need the carbon building up on my intake thanks to the egr. If your engine burns a little oil ,might even get a nice oily, carboned up mess in the intake....oh...yeah I can't wait to force that down my engine's throat.
Too many people including myself have disabled the egr with NO adverse affects , DO NOT need to adjust fuel or timing. Put a plate under it, reinstall it, looks like it is working in case the smog police have a look under the hood. On a TPI you may have to just put the plate only, not sure.
It would be nice to turn the egr off or set the test to a higher temp in the prom for no more SES light .
Argue all you want, cooler air makes more horsepower, unless you like your engine to ingest hot, dirty, possible oily air that carbons up your intake.
Disable it, your engine will thank you.
Bill E.
Bill E.
Car: 91 Red Sled
Bill E.
Bill E.
It's a fact that EGR will lower your combustion temps and combustions temps can be seen (if you don't change ignition timing) in EGTs. And EGTs are lower, combustion temps are lower.
Now to get to your point about EGR hurting your engine. Let me ask you what puts more wear and tear on an engine, one that is burning less fuel or one that is burning more, same engine, just different fuel consumptions. Running EGR could increase your engines life if you do a lot of highway driving or if you have lots of rear gear and are spinning the snot out of your engine on the street.
I do agree with you about the oil consumption but trust me, it won't be oil from the EGR, it'll be carbon. If oil isn't burning up through the combustion process then you have other problems. The only way oil will be ingested is through the PCV system. If you still have a functional PCV then the oil in the intake is 99% from that, not EGR. Oh, and the carbon that does go through the intake when you're running ***** to the wall will most likely pass through the engine with no troubles.
Weigh the reasons before going one way or the other.
Car: An Ol Buick
Engine: Vsick
The fuel isn't perfectly homogenious in the chamber.
EGR helps to limit the peak temps within the chamber.
So the peaks are lower, and in that reguard, it does slightly lower the temps..
And beings the added gases are usually hotter, it does lower the threshold to pre-ignition, and detonation. In some of the newer stuff they're making an effort to drop the EGR temps, pre intake runner.
Ask any tuner, cooler denser air will allow for more timing. That wonderful EGR is introducing hot gases which is more likely to
cause detonation.
For example, a Hypertech thermomaster chip....more timing dialed in so therfore they want a free flowing exhaust to remove exhaust gases to lower temp and a colder thermostat.
An another example would be supercharging , raises inlet temp due to compression which without an intercooler to remove the excess heat you would need to retard timing.
Bill E.
Originally posted by JPrevost
I can't agree with you on everything you said so here is something to chew.
Egr lowers combustion temps compared to what ? A fully filled combustion chamber with cooler, denser air .
Theoretically since I am burning a cooler denser charge , fully filled chamber, and making more power, I could back out of the throttle compared to an EGR car. This is silly egr does not help out mileage or longevity of your engine.
Common sense and basic engine operating principles people,
I am a jet engine mechanic, build 'em for a living . These engines make more thrust on cool day than a warm day every time. Push them less on a cool day = engine longevity vs. push engine harder on the warm day to get same thrust as cool day and it'll be off the wing and in the shop way before the engine ingesting nice cool air.
Bill E.
Car: An Ol Buick
Engine: Vsick
WRONG,
cause detonation.
WRONG,
cause detonation.
I said it lower the threshold for detonation. That means it is more likely to detonate.
The hyper stuff is about laughable, for years all the did was lower a few enable temps, and usually only the fan operating temps.
Ya, when I get a chance I'll ask a tuner, ya know any?.
Car: An Ol Buick
Engine: Vsick
Originally posted by IroczInOz
Okay Grumpy I am going to ask you straight out.
Would you enable EGR or not?
And at what temps would you have it enabled at if you did use it?
Car: check
Engine: check
Transmission: check
Well, EGR is used to lower combustion temperatures. In this manner it lowers the exhaust emissions of NOx. Don't have to believe me, here is quoted text and a reference:
"Higher combustion temperatures induce an over-proportional increase in NOx formation, and because exhaust-gas recirculation (EGR) reduces combustion temperatures, it represents a particularly effective means of controlling NOx emissions."
Automotive Handbook, 5th edition, 2000. Bosch, Robert. Stuttgart. p. 520, para. 1.
This is from the section titled "Exhaust emissions from spark-ignition engine." Just so there is no misunderstanding that this is for some other type of engine.
RBob.
RBob.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Might reread what your claiming is wrong.
Sure, the hypertech is laughable, but it is given as an example only that lower temperature intake air will allow for a more aggressive timing curve as opposed to a warmer intake charge.
A tuner, ask TPIS OR LINGENFELTER, they all will tell anyone that cooler makes makes more power, period.
Bill E.
RBob.
RBob.
If it is such a GREAT thing why is EGR off at WOT, because it is costing you power.
You EGR guys keep smoking whatever you are, I build jet engines for a living and these engines operate under the same basic principles as any other engine that requires fuel and air ( about covers them all don't it)...
Cooler denser air will ALWAYS make more power or thrust than hot air and the cooler charge will be much easier on the engine because it will not be on the ragged edge of detonation.
ANy cooling effects of adding inert ( spent) gases into the mix are more than offset by the increase in temp associated with the inert exhast gases.
Smoke 'em if you got 'em, oh forgot you guys already are....
I am done with this , basic engine principles apply to every engine made, EGR is for emissions, no other benefit...period.
Car: 91 Red Sled
You're not thinking straight. An engine designed for thrust has almost no bearing in the automotive world other than they both convert chemical energy into mechanical engery.
In a car on the highway it doesn't require much horespower to sustain a constant cruising speed. Take that and chew it. There are 2 kinds of highway driven vehicles. Those that are geared for acceleration at low speeds and only have the throttle open to sustain an engine speed, those higher engine speeds are creating more heat from yes, more fuel BUT more timing (lower map loads) than an engine with more TPS and lower rpm. BUT those cars that are using slightly more TPS because there gearing is designed for keeping the engine lower will still burn less fuel and gain mpg if it is making enough torque at that vehicle/engine speed to maintain cruising speed.
I don't care what you think but saying EGR is nothing but an emissions tool is
. It's implementation might have been only for emissions but so was EFI. And please don't go and tell me EFI is only good for emissions or I'll have to reach through this monitor and bitch slap you.
Plain and simple, EGR will lower combustion temps resulting is less fuel, less fuel will equate to less power and a given constant engine speed. At 65mph spinning at 3000rpm if you're making a lot of power you can gain some mpg with EGR.
Oh, and a hotter intake charge will help with the homoginious intake charge resulting in again the ability to increase timing. I can argue this till we're all blue in the face but the increase in intake charge temps will not result in pre-ignition. Another mis conseption is that run the most timing possible without pinging but unless you have a calibration that removes timing as speed increases you will be shooting yourself in the foot. That's already been brought up so do you think that's BS too?
I'm sorry you had to go and bring up your "experience" but let me again state that you're experience doesn't make you any smarter or wiser than the other man.
Mike, disable it in your situation. You'll be better off until gas prices increase to $4/gal. When that day comes we'll probably all be running water injection on our n/a cars!
. It's implementation might have been only for emissions but so was EFI. And please don't go and tell me EFI is only good for emissions or I'll have to reach through this monitor and bitch slap you.Plain and simple, EGR will lower combustion temps resulting is less fuel, less fuel will equate to less power and a given constant engine speed. At 65mph spinning at 3000rpm if you're making a lot of power you can gain some mpg with EGR.
Car: 88 Camaro SC
Engine: SFI'd 350
Car: 88 Camaro SC
Engine: SFI'd 350
Car: An Ol Buick
Engine: Vsick
And in talking with Jason Haines at Lingenfelter he has impressed me.
Care to try some more name dropping?.
BTW, Jason dropped by the house for Pizza a few years ago.
Car: An Ol Buick
Engine: Vsick
Backpressure will open the EGR valve.
Instead of bailing you ought to hang out and maybe learn a thing or there instead of assuming you know it all. While some of what you said is true, not all of it is.
Car: An Ol Buick
Engine: Vsick
Originally posted by dimented24x7
One of the reasons its off at WOT is that theres no vacuum to operate the valve
PLEASE.
BACKPRESSURE WILL OPEN IT.
Yes, EGR in some applications (like the 3rd Gens that this list is specifically for), does open at WOT.
Yes, they taken measures in the later stuff to prevent it, or better manage it.
My experience is irrelevant, I guess it is when dealing with idiots that refuse to acknowledge basic engine principles, cooler air makes more power than hot air....period. Jet engines run on air and fuel, don't they.....jet engines make more thrust (power) with a cooler denser air charge....push engines less on a cooler day and therefore burn less fuel than a warmer day....How is this not applicable, I mean you said jet engines have little to do with this ?
What is your experience, maybe a desk jockey, built any engines lately, dynoed them, I have......You pipe in cool outside air ...guess what happens....low and behold a few extra hp.
What you can't get through your head is the offset of any gains because of the increase in temp of air intake due to hot exhaust gases being introduced.
Your theoretical increase in mileage is
But I'll play, my engine making more power on clean, cooler, denser could back out of the throttle some compared to your engine breathing dirty, hot exhaust gases, theoretically, of course.
Engine theory 101..........Give me your best shot...
Bill E.
Build a darn cat's whisker position detector and get back to me.
PLEASE.
PLEASE.
I guess they have "taken measure to prevent it" for a reason ?
Must not be a good thing to have that EGR open at wot ? Actually it is bad thing to have the EGR open ever.
I guess you never actually tested the EGR operation on a 3rd gen have you?
insist on forcing hot exhaust gases down their engine's throat.
If hot exhaust gases are such a wonderful thing, I wonder why turbos have INTERCOOLERS ?????? Obviously the quantity is much different here, but the basic principle is the same, cooler air is better.
"Maybe learn a thing or two"
I don't think you two could teach a duck to go to water.
Car: 88 Camaro SC
Engine: SFI'd 350
PLEASE.
PLEASE.
The only one that would really open up all the way is the pintle type that was run by the pcm in my s-10. At wot, it would open fully and allow crap from the roof of the CC to enter into the valve and plug it up. Mustve blocked open about 10 times before I just unplugged it for good.
Car: 91 Red Sled
You are a joke. You think you know it all but guess what, it's time for me to whip out the big guns for the pathetic person sitting in front of your monitor.
Funny you mention the whole "how many engines" and have you tuned an engine on a dyno.... I have just finished tuning a motor on a dyno tonight, yes tonight, about 10 minutes ago to be exact. Been working on setting up our engine in the grad students dyno for the past few days and it fired up last nite. Want a picture, I can send it.
Oh, and RBob, the wideband is working great. We even have an actual NTK controller that was given to us to use for the weekend, I told them we didn't need it
. Have you ever seen their insides, if not, I'm your man.
I still don't see where you're going with this "cooler air is better" BS when we're talking about milage, not power. Oh, and BTW, intercoolers aren't all they're cracked up to be if you know how to lower the intake temps using fuel and/or water.
I can't believe you had to go into the name calling, are you really a jet mechanic, because you're starting to place doubt in my mind.
EGR can increase your milage for some applications. I never said it wouldn't and could you please quote me where I disagreed with the cold air more power statement?
I think you need to go back and re-read my reply.
I also can't understand why you think that just because you're using less throttle, that you're burning less fuel than somebody with the same throttle position and hotter air. Again, have you ever looked at how much power is really needed to sustain vehicle cruising speeds. Next thing you'll be telling me is that your modified engine gets better milage all around town then you're stocker because you have to use less throttle
. When you ever get to understanding more than the basics, we can have this little chat again, you might learn something. If it were as easy as you claim to make a perfect motor I think the Automotive engineering world would be out of buisness. What is your understanding of BSFC, engine efficiency, combustion chamber efficiency, and everything else that is critical to an engine tune? How about understanding on resonance tuning and exhaust tuning? What about pumping losses through different components and various parasitic drag? How about your knowledge of various waterpump designs and cooling systems along with ceramic coatings?
Let me make you feel even smaller since you felt it the inclination to call BS on me and call me an idiot. When was the last time you saw a thirdgen gasoline powered vehicle with no direct drive thrust propultion.... because that's about all you would be standing on in this little arguement.
Grumpy, I understand that under backpressure EGR will open, this is old knowledge to me, okay, maybe only 3 years or so.
Oh, and for some of you that are interested, I was tuning an unrestricted Honda CBR600 F4 up to 12500rpm.
. Have you ever seen their insides, if not, I'm your man.I still don't see where you're going with this "cooler air is better" BS when we're talking about milage, not power. Oh, and BTW, intercoolers aren't all they're cracked up to be if you know how to lower the intake temps using fuel and/or water.
. When you ever get to understanding more than the basics, we can have this little chat again, you might learn something. If it were as easy as you claim to make a perfect motor I think the Automotive engineering world would be out of buisness. What is your understanding of BSFC, engine efficiency, combustion chamber efficiency, and everything else that is critical to an engine tune? How about understanding on resonance tuning and exhaust tuning? What about pumping losses through different components and various parasitic drag? How about your knowledge of various waterpump designs and cooling systems along with ceramic coatings?Let me make you feel even smaller since you felt it the inclination to call BS on me and call me an idiot. When was the last time you saw a thirdgen gasoline powered vehicle with no direct drive thrust propultion.... because that's about all you would be standing on in this little arguement.
"Just dynoed one 10 minutes ago" REALLY
"You can't understand why I think if I am using less throttle that I would be burning less fuel " compared to the exact vehicle except with egr. Too much for you to follow. Besides makes about as much sense as your bs on egr helping mileage and I was just theoretically "playing along" with that scenario.
Damn dude, you should have been a rocket scientist. Or a world class engine tuner ( thinks he is) that should have some test data backing his claims to better mpg with egr.
You brought up this bs about mileage, not me, sounds like you'll admit EGR hurts overall power output.
Said in other posts I don't claim to know everything, back up your bs about mileage increase with proof.
This time I am done, I don't deal with ******* or idiots and you just doubled down....
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
This has caused me to drop $45 on a book! The book that RBob quoted, I've heard that it's an excellent resource. Automotive Handbook by Robert Bosch. Just went to amazon.com, and I'm about to order it. I know htere's much more there than I'll ever get a grasp on, but I know I will learn SOMETHING from it!
Now back to topic.....
I'm sure EGR DOES decrease overall power, and I bet everyone will agree that when you put less air/fuel mixture in a cylinder due to the fact that some exhaust gasses have been allowed in there at the same time, you will decrease power. Driving down the highway, I bet it's barely noticeable due to the fact that it takes far less power to ACCELERATE TO a speed than to MAINTAIN a speed.
Makes sense to me that if you have less air/fuel mixture to burn, you're going to generate less heat, even if the inert gasses that cause there to be less air/fuel mixture are hot. It all becomes extremely hot when compressed. There are engines designed around this principal! I think the guy that came up with it had a last name of diesel.
Now, I don't currently run EGR on my engine, have no problems with detonation, etc.... and I really doubt I will be running it in the future due to the difficulty of hooking it all up (vortec type, aka fastburn heads) but if the provisions were there, I think I would keep it working.
As for engine longevity, look at all the 60's engines that were worn out before 100,000 miles, then look at my 84 LG4 305 WITH EGR that run until 215,000 miles (still would be if I hadn't pulled it!) and all the other newer vehicles that last a lot longer than the older stuff. I can't believe that EGR has much, if any of a negative impact....
Now, even though I've argued in favor of EGR, it does seem sort of silly to put the **** that is a by-product of combustion back into the engine, that would be like eating your own.....well nevermind, I think we all get the point. The strange thing is that it must really work, or the OEM's wouldn't be using EGR......
Pick a thought and stick to it. You keep bouncing around between mileage and power so much that it doesn't seem you have a train of thought.
Want to prove you're "king of automotive knowledge" [which you've claimed not to be a few times already], go burn a couple of chips and give datalogs stating that EGR has no effect on mileage. Then we'll believe you. Until you give us hard proof [or mildly solid, lol], you might want to take some inert gases out of your ego before it explodes.
My $.02 on the whole deal, I had a malfunctioning EGR like most 3rd genners do. I installed a chip where EGR was disabled and went from 14MPG to 21MPG on the highway. Do I care if EGR gets me more mileage? Not right now, I'm still damn happy with a 50% increase. Will I check it out later? Maybe, but right now I've got other things to take up my time.
Car: An Ol Buick
Engine: Vsick
If it is opening under WOT , it should not be, that is just what you don't want especially at wot .
Just because you read something doesn't mean it's true.
Car: An Ol Buick
Engine: Vsick
Which types? Digital types? Positive backpressure ones?
This list is supposed to be third gen specific, so unless stated otherwise, the Charter would govern the fact that the info. being related too would be 3rd gen specific.
Car: An Ol Buick
Engine: Vsick
I was driving back then, and that wasn't the typical case, from what I saw.
With all the fuel changes, and improvements the comparison of 60s engine life to now, really isn't fair. Not to mention lubricants.
Bearing wear (assuming the tune is right), is primarily about bearing loads, and oil temps.. Rings are about filtering material.
While the new low tension rings may help with cylinder wear, They're more for MPG.
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I was reading an amsoil article and they were stating the same fact that engines from the 60s compared to modern cars dont have alot of the same characteristics. For one the materials tolerances and quality control of older engine parts was not as scrutinized as much as today. And like already stated the new formulas for lubricants to last for better mileage has also improved. I think up until you put all these considerations into play then you can have a good argument for this statement.
Car: 84 Z28
Well, I tried, and thanks for setting me straight.
Now I'll just leave it, and not argue unless I find some PROOF either way.
Car: 88 Camaro SC
Engine: SFI'd 350
Any one you'll find on a 3rd Gen..
Car: 84 Z28
This should explain GM's purpose behind the EGR system, in Service Manual language.
Car: An Ol Buick
Engine: Vsick
PARTICULARY, in the emissions area.
HoosierinWA
Oct 7, 2015 10:15 AM
