miniram bin
Old Feb 24, 2004 | 05:53 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
miniram bin
just got a miniram and installing it this weekend. My current setup is not tuned with the chip other than injector constant and some minor lower ve work. I was wondering if anyone had any ideas on a good starting point before i start it up and try to drive it. maybe somethings that need to be changed that will help me get closer before i can get a chance to tune it.
Old Feb 24, 2004 | 06:53 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Pump Shot. Acceleration Enrichement vs. %TPS. Almost all MiniRam setups need these raised about 10-20%. If you get an off-idle stumble or an off-idle backfire then you know that you are need more pump shot.
Tim
Old Feb 24, 2004 | 08:51 PM
ULTM8Z's Avatar
Traxion is absolutely right. I had to add just about that much pump shot to smooth out the off-idle stumble.
Other than that it will drive. Though for max power you're going to have to remap the fuel and spark for the Miniram. It's characteristics are going to be a lot different than the TPI. It's going to also depend on the rest of your engine combination- i.e. cam, heads, and exhaust.
I actually started out copying an LT4's fuel and spark MAPs. Since the manifold and cam are similar to a ZZ4/Miniram combo, I figured it was a good place to start. Seems to work just fine. I did some tweaking here and there to get my BLM's just right, but it's running great now.
Old Feb 24, 2004 | 09:30 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
hey ultm8z you wouldn't happen to have the lt4 fuel and spark maps that you could email me do you? I feel like that might be a good place to start.
Old Feb 24, 2004 | 10:18 PM
ULTM8Z's Avatar
btcamaro, you have mail.
Old Feb 24, 2004 | 10:46 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
ULTM8Z Can I have a look at those tables too?
Old Feb 24, 2004 | 11:27 PM
ULTM8Z's Avatar
SlowIroc-Z you have mail.
Guys remember that you'll still have to do some tweaking. The thing with this is that it's closer to a Miniram than a TPI which makes it a good starting point.
Also, the way I'm viewing it is with Tunercat and the $EE tdf file. I'm not sure what software you're all running. I downloaded it as a .lt1 file and used the tuneconv software to turn it into a .bin.
Old Feb 25, 2004 | 01:58 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
sweet!
Can u send me the fuel and spark curves too for a LT4?
been poking around for a peek at those
thanks
Jeremy
Old Feb 25, 2004 | 02:36 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I hate to ask but could you send me a copy as well? I'm using a lt1 but I'm having the same problems as traxion metioned.
Old Feb 25, 2004 | 02:57 PM
ULTM8Z's Avatar
Guys, I'll e-mail you when I get home tonight.
Traxxion, there appears to be significant interest in this LT4 file. Maybe we should put it up on the site for download?
Old Feb 25, 2004 | 04:30 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
I have a stealth ram but I would love to have a copy of this bin as well. Would you email me a copy kind sir?
Thanks,
John
jaylisa88@hotmail.com
Old Feb 25, 2004 | 05:04 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Those without an $EE definition file will not be able to read it
Old Feb 25, 2004 | 05:55 PM
jjvette's Avatar
Car: 89 vette
Transmission: a4
I'll take it in graph form or spread sheet as well.
I just want to compare the fuel and timing cuves to what I'm presently running. Maybe I can find the $EE definition for tunerpro.
I'll take whatever I can get!
Thanks,
John
Old Feb 28, 2004 | 03:59 PM
3.8TransAM's Avatar
got the email, not sure what im looking at, runs from 2k thru to 7k and from 20kpa to 100kpa in 5 point increments?
And if this is the spark table? would i divide by .3 to make it workable in normal timing terms
later
Jeremy
Old Feb 28, 2004 | 04:16 PM
ULTM8Z's Avatar
Look at the tabs on the sheets. There's main spark and extended spark as well as VE and extended VE.
The spark table is just the total number of degrees of advance vs MAP and RPM. The ECM will also use the value in the constants table for initial advance set by you at the distributor.
So lets say you have 6° of initial advance at your distributor (the factory value). And also let's say you're crusing along at 2200 rpm and you have 50 Kpa of manifold pressure. Go to the table and look up 2200 rpm and 50 Kpa. You get 40° BTDC. However, this is total timing. So since you already have 6° at the distributor, the ECM will add 32° to get to 40°.
Not sure about the dividing by .3 thing????
Old Feb 28, 2004 | 04:34 PM
3.8TransAM's Avatar
My bad
combination of stupidity, blindess and new computer issues...
thanks alot got them all printed now too
thanks
Jeremy
Old Feb 28, 2004 | 06:36 PM
TRAXION's Avatar
I would suggest using Craig's new file system over on his site. That way we don't have multiple sites.
Tim
Old Feb 28, 2004 | 08:16 PM
ULTM8Z's Avatar
Ohhhhhh yeaaaaahhhhh.... good idea.
gixxer92
Apr 12, 2022 12:09 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
BWilcox
Sep 20, 2015 12:19 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
