Interesting Injector feeding idea
I found that at blowerdriveservice.com
Why i think its interesting is because I know alot of you guys use extra injectors or carb converted to EFI intakes. It would be cool to be able to get away from a fuel rail and use a manifold with bent brake line.
How do you think these guys are doing this? Do you think they are tapping the injector to fit a flare nut or what?
Car: 91 Red Sled
I can't make any assumptions on how they are doing it but I don't like the idea. The fuel rail has 3 purposes all in one small package. First it supply's fuel (duh), it also seals the injectors to the manifold. It's third purpose is to align the injectors for a common direction into the port. Without the rail you'll have to do all of those and still find a place for a regulator.
It looks almost like the system GM had with there vortec engines back in 96 with the CPI. The advantage of the CPI was it's size. The injector(s) were remotely mounted and the fuel was then passed into a small tube to be injected into the port.
What advantages do you see in that system other than it looks cool (which it definatly does).
the injector positioning on my car has always been a problem because I have a big roots supercharger. I would like to reposition them and this is interesting because other than having a physical restraint to the injector, your possiblities are almost endless.
Car: An Ol Buick
Engine: Vsick
Re: Interesting Injector feeding idea
Not hardly the way I'd do it for a street car.
There are top feed injectors that us hose ends.
Pop a hose pre regulator, and you have fuel spraying about at several gals a min, and with a hot exhaust, and ignition system around it's an invite for disaster.
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Re: Re: Interesting Injector feeding idea
They make threaded bungs for injectors.
I thought normally the injectors on a 671 were located above the blower. Guess it doesn't really matter. Top Fuelers have them in both locations since they use gpm.
I would be more worried about vibration cracking one of those lines.
is there a solinoid on the end or is it just a tube coming from a injector.. thats truely interesting.
On the vortec injection system, the tubes that run from the injector bank to the manifold, have popit valves on the ends that goes into the manifold. They are there to keep fuel from draining out of the tubes when the injectors arn't firing. They are set at a certain pressure that is overcome by the injector opening also providing the coneshaped spray for better atomization of the fuel.
Steve
Steve
CarGuyDennis
137
Dec 6, 2016 11:02 PM
ambainb
Apr 25, 2016 09:21 PM
