Maybe a bit OT...16144288 $A0 ECM
Old Mar 22, 2004 | 11:26 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Not much info on this one on GMECM. Anyone know of a hac for this one? It is from my 1992 Blazer, 4.3L Vortec, 4L60 trans (might be 4L60E).
Old Mar 23, 2004 | 06:14 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Nope can't help you there, I'm tuning a 92 truck with that ecm for a buddy and had to buy the Tuner cat TDF.
Old Mar 23, 2004 | 06:17 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Strange thing is that WinALDL supports it. I am just trying to tune the low end knock out of it. Crap!!!
Thanks anyway.
Old Mar 23, 2004 | 07:40 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
About the only thing I know about that ECM is that it's pin compatible with a 1227747, or 1228062, at least with a 4.3 full size truck bin in it. Also, you must have a 700R4 trans (or 4L60, not "E") because it is just an ECM, not a PCM!
If you find anything, I would be interested, I have one of them sitting here somewhere.....
Old Mar 23, 2004 | 08:15 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Well, I'll be datalogging it tomorrow on the way to work now that I know WinALDL will log it. I'll let you know what I find.
Old Mar 23, 2004 | 10:14 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
I just did another WWW search and found out that this ECM is actually for a TBI system. the 4.3L I am talking about is a Vortec MPI engine.
Looks like I'll be pulling the ECM out to see which one it is. I thought I had gotten lucky.
Old Mar 24, 2004 | 06:11 AM
BMmonteSS's Avatar
Car: 84' Monte
there are about a million different ecm's GM used between 90-93 particularly the 4.3. From what I can tell in Tuner Cat 8062 is an exact clone of the 747. Let me check the locations of some of the main tables and I'll hint to you guys if you should try to mod a 747 ecu.
Old Mar 24, 2004 | 06:14 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
I'll pull the glovebox today and tell you which one the Blazer has. I certainly hope it is one that has been hac'd so I can create a TunerPro ECU for it.
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
ptc92rs
Sep 11, 2004 12:34 AM
mult68
Aftermarket Vendor Review
Dec 10, 2001 09:51 PM
84Camaro305
Nov 8, 2001 09:48 PM
