blm table, can some one help me
Old Apr 4, 2004 | 04:31 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
understand what i need to do to this poor motor and Y
Narrow Latest
RPM \ MAP 20 30 40 50 60 70 80 90 100
400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
800 0.0 0.0 112.0 114.0 0.0 0.0 0.0 0.0 0.0
1200 0.0 114.0 108.0 116.0 122.0 121.0 129.0 131.0 0.0
1600 0.0 108.0 108.0 110.0 113.0 129.0 129.0 128.0 0.0
2000 0.0 108.0 108.0 108.0 108.0 108.0 124.0 116.0 0.0
2400 0.0 108.0 108.0 0.0 0.0 0.0 0.0 123.0 0.0
2800 0.0 123.0 0.0 0.0 119.0 0.0 0.0 0.0 0.0
3200 0.0 0.0 0.0 108.0 0.0 0.0 0.0 0.0 0.0
3600 0.0 0.0 108.0 0.0 0.0 0.0 0.0 0.0 0.0
4000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
4400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
4800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
5200 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
5600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
6000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
6400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Narrow Avg
800 0.0 0.0 109.7 113.0 0.0 0.0 0.0 0.0 0.0
1200 0.0 108.4 108.7 109.7 115.9 118.6 124.9 129.0 0.0
1600 0.0 108.5 110.2 108.4 113.7 117.3 123.9 122.4 0.0
2000 0.0 108.0 108.0 108.5 113.4 117.5 124.2 123.8 0.0
2800 0.0 123.0 0.0 0.0 120.5 0.0 0.0 0.0 0.0
3200 0.0 0.0 0.0 108.5 0.0 0.0 0.0 0.0 0.0
Narrow # Sapmles
400 0 0 0 0 0 0 0 0 0
800 0 0 3 15 0 0 0 0 0
1200 0 19 53 21 17 40 35 3 0
1600 0 34 21 5 22 40 13 5 0
2000 0 1 2 4 5 12 9 19 0
2400 0 2 1 0 0 0 0 1 0
2800 0 1 0 0 2 0 0 0 0
3200 0 0 0 2 0 0 0 0 0
3600 0 0 1 0 0 0 0 0 0
4000 0 0 0 0 0 0 0 0 0
4400 0 0 0 0 0 0 0 0 0
4800 0 0 0 0 0 0 0 0 0
5200 0 0 0 0 0 0 0 0 0
5600 0 0 0 0 0 0 0 0 0
6000 0 0 0 0 0 0 0 0 0
6400 0 0 0 0 0 0 0 0 0
Narrow Avg 10
800 0.0 0.0 109.7 113.2 0.0 0.0 0.0 0.0 0.0
1200 0.0 108.8 108.0 110.5 115.5 120.9 125.5 129.0 0.0
1600 0.0 108.0 111.7 108.4 112.7 118.8 123.2 122.4 0.0
2000 0.0 108.0 108.0 108.5 113.4 116.7 124.2 124.8 0.0
Narrow Std. Dev. 10
800 0.0 0.0 1.7 3.6 0.0 0.0 0.0 0.0 0.0
1200 0.0 1.8 0.0 3.6 5.5 4.8 2.7 1.6 0.0
1600 0.0 0.0 5.0 0.8 1.0 4.4 2.7 3.7 0.0
2000 0.0 0.0 0.0 0.9 5.0 3.8 2.0 3.4 0.0
2400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
2800 0.0 0.0 0.0 0.0 1.5 0.0 0.0 0.0 0.0
3200 0.0 0.0 0.0 0.5 0.0 0.0 0.0 0.0 0.0
3600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Wide Latest
800 0.0 112.0 112.0 114.0 112.0 0.0 0.0 0.0 0.0
1200 0.0 110.0 112.0 108.0 108.0 116.0 116.0 117.0 0.0
1600 0.0 108.0 108.0 108.0 108.0 116.0 110.0 123.0 0.0
2000 0.0 109.0 113.0 114.0 114.0 122.0 122.0 122.0 123.0
2400 121.0 108.0 125.0 110.0 0.0 0.0 0.0 124.0 123.0
2800 0.0 108.0 110.0 111.0 119.0 118.0 118.0 123.0 123.0
3200 0.0 0.0 108.0 108.0 108.0 0.0 121.0 123.0 123.0
3600 0.0 0.0 108.0 0.0 0.0 121.0 121.0 123.0 123.0
4400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 108.0
Wide Avg
800 0.0 112.0 109.4 112.6 112.0 0.0 0.0 0.0 0.0
1200 0.0 108.4 109.1 110.9 115.6 118.3 124.5 127.3 0.0
1600 0.0 108.6 110.1 110.3 114.5 117.5 123.7 125.7 0.0
2000 0.0 108.6 111.9 111.4 113.4 117.9 124.5 123.5 121.4
2400 121.0 112.4 114.1 110.0 0.0 0.0 0.0 119.7 121.7
2800 0.0 113.0 112.8 114.7 121.0 118.0 121.2 123.0 123.0
3200 0.0 0.0 108.0 111.4 113.0 0.0 121.0 123.0 123.0
Wide # Samples
800 0 3 34 124 1 0 0 0 0
1200 0 283 308 130 102 188 178 37 0
1600 0 235 131 57 139 238 130 30 0
2000 0 26 27 29 65 106 136 69 26
2400 1 9 7 1 0 0 0 18 53
2800 0 3 6 12 3 1 6 3 8
3200 0 0 2 14 4 0 1 1 1
3600 0 0 1 0 0 1 1 1 1
4400 0 0 0 0 0 0 0 0 1
Wide Avg 10
800 0.0 112.0 111.6 113.7 112.0 0.0 0.0 0.0 0.0
1200 0.0 111.7 108.5 109.7 118.3 117.5 123.5 129.2 0.0
1600 0.0 108.0 108.0 109.5 111.5 120.8 122.7 124.4 0.0
2000 0.0 108.1 111.9 111.3 113.1 116.3 121.1 119.1 125.2
2400 121.0 112.4 114.1 110.0 0.0 0.0 0.0 120.2 124.0
3200 0.0 0.0 108.0 109.4 113.0 0.0 121.0 123.0 123.0
Wide Std. Dev. 10
800 0.0 0.0 1.1 4.0 0.0 0.0 0.0 0.0 0.0
1200 0.0 3.1 1.2 3.2 4.7 5.3 6.7 4.3 0.0
1600 0.0 0.0 0.0 3.0 3.5 5.8 7.6 3.4 0.0
2000 0.0 0.3 5.1 3.2 4.3 4.0 5.7 5.0 4.4
2400 0.0 6.4 7.2 0.0 0.0 0.0 0.0 4.0 2.0
2800 0.0 7.1 6.2 5.9 1.4 0.0 2.0 0.0 0.0
3200 0.0 0.0 0.0 2.2 5.0 0.0 0.0 0.0 0.0
Narrow Correction 10
400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
800 1.000 1.000 0.857 0.884 1.000 1.000 1.000 1.000 1.000
1200 1.000 0.850 0.844 0.863 0.902 0.945 0.980 1.008 1.000
1600 1.000 0.844 0.873 0.847 0.880 0.928 0.963 0.956 1.000
2000 1.000 0.844 0.844 0.848 0.886 0.912 0.970 0.975 1.000
2400 1.000 0.844 0.844 1.000 1.000 1.000 1.000 0.961 1.000
2800 1.000 0.961 1.000 1.000 0.941 1.000 1.000 1.000 1.000
3200 1.000 1.000 1.000 0.848 1.000 1.000 1.000 1.000 1.000
3600 1.000 1.000 0.844 1.000 1.000 1.000 1.000 1.000 1.000
4000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
4400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
4800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
5200 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
5600 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
6000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
6400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
Wide Correction 10
800 1.000 0.875 0.872 0.888 0.875 1.000 1.000 1.000 1.000
1200 1.000 0.873 0.848 0.857 0.924 0.918 0.965 1.009 1.000
1600 1.000 0.844 0.844 0.855 0.871 0.944 0.959 0.972 1.000
2000 1.000 0.845 0.874 0.870 0.884 0.909 0.946 0.930 0.978
2400 0.945 0.878 0.892 0.859 1.000 1.000 1.000 0.939 0.969
2800 1.000 0.883 0.882 0.896 0.945 0.922 0.947 0.961 0.961
3200 1.000 1.000 0.844 0.855 0.883 1.000 0.945 0.961 0.961
3600 1.000 1.000 0.844 1.000 1.000 0.945 0.945 0.961 0.961
4400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 0.844
Old Apr 4, 2004 | 07:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Well, looks like a little tuning of the VE table(s) is in order. Where ever the BLM is less then 128 is too rich, so lower the VE. Anywhere the BLM is > 129 is too lean and you need to increase the VE.
The last couple of tables give the correction factor. Mutiply the VE term at that location by the correction factor for the new VE term.
As far as to the whole meaning of wide vs. narrow I have no idea. The WinALDL site and/or doc should help with that.
RBob.
Old Apr 4, 2004 | 09:10 PM
c4boom's Avatar
Engine: l98 and lo5
man i would think that with my setup i would be able to use all the fuel in the stock programing. dose this mean that all my work was for nothing
i have a holley 670 tbi, projection intake, headers, compcam xe249h-12 cam, full flowmaster catback, and a 14X3 K&N filter. do you think that with the stock heads it just isnt able to make any more power than stock LO5
Old Apr 4, 2004 | 09:48 PM
91L98Z28's Avatar
Car: Z28
whenever you change the airflow potential of a motor, you are going to have to change the fuel maps, plain and simple.
changing the throttle body/TBI, intake, and the entire exhaust system, will certainly change the airflow potential (after all - that's why you upgraded all these parts, right?) - so now you have to tell the computer that you're flowing more air.
also note that since you changed the TBI, you probably have different size (lbs per hour of fuel flow) injectors, so that requires a little bit of tuning too.
it looks like you are almost universally rich, so I'd hazard a guess that you switched to bigger injectors.
the good part is you haven't changed too much, injectors and intake/exhaust are pretty easy to tune for. first thing first is to correct the injector constant (or the equivalent of the injector constant in whatever code/ecm you are running), then start roughing in the VE tables to match your combo. increasing the injector constant/base pulse width (whichever your setup uses) will get the lower end stuff back in line, and then you can work with the ve tables to get the high end stuff back in line.
...at least, that's how i'd do it.
Old Apr 4, 2004 | 10:48 PM
c4boom's Avatar
Engine: l98 and lo5
i think i herd that the holley unit uses 65 pph units.
Old Apr 4, 2004 | 10:58 PM
c4boom's Avatar
Engine: l98 and lo5
the way that i was thinking was that after all the mods air gets in beter that would make it go lean. but with the 65' s in place of the stock ? 55's ? it made it go rich. pluse the cam and the beter intake would that make it have less vacume and cause the motor to dump more fuel un neededly
Old Apr 5, 2004 | 12:45 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With the mods your changing the powerband of the motor. The relative VEs will be less then the L03 at low engine speeds and higher then the L03's at higher speeds. Itll be rich down low, and possibly lean at higher rpms and loads
Old Apr 5, 2004 | 12:55 AM
Car: 88 Camaro SC
Engine: SFI'd 350
With the stock heads you probably wont be able to make much power. Should be able to make some decent torque, though. I have a similar but less agressive grind in my 350 and it has insane throttle response and some torque with the small runner heads, dual plane, and dinky *** headers. Probably a good set of heads to go along with that would be a set of mildly worked over 305 TPI heads or similar small runner heads.
I wouldnt pass judgement on it too fast. The performance should improve as you get stuff dialed in.
Old Apr 5, 2004 | 12:59 AM
Car: 88 Camaro SC
Engine: SFI'd 350
RBob.
I think narrow tosses extreme values to either side of 128 out. I would have liked to see an option that displayed the mode instead, though. I think it would have been more useful.
Old Apr 5, 2004 | 11:54 PM
c4boom's Avatar
Engine: l98 and lo5
how do you tell the mode do you do that by recording the flag data. also i now know that i am going to have to get into prom burning. how much am i missing out on with the programming as it is now. i would love to hear that there is a bunch of untaped torque that i am missing if so how much you think thank you for all the help now just to find a new programer and hop it is not broke when i get it like last time
Old Apr 6, 2004 | 09:04 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Tuning EFI is amazing.. The wrong tune can put a 500hp street/strip car into valet mode.
-- Joe
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
