Effects of incorrect Cyl Displacement?
Old Apr 12, 2004 | 09:20 PM
nhromyak's Avatar
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
Can anyone tell me what effects I may encounter with too small a Cylinder Displacement setting will have?
It was set for 712 CCs. But my BBC is at 833.
A 15% difference!
Old Apr 13, 2004 | 08:26 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
OK, no one answered?
Should I be looking or otherwise modifying this at all???
Old Apr 13, 2004 | 10:11 PM
JohnL's Avatar
'730 and a TBI- interesting combination- I hope someone's worked out how to make it drive P&H injectors. What mask ID are you running?
IIRC, some masks don't have anything change with cylinder size, while in others, 15% too small a cylinder size, and you have 15% too little fuel. The masks I'm familiar with use an injector constant that's based on L/gm per sec, and it's critical to be correct, but YMMV.
It probably won't hurt to use the right number (unless the wrong one has been used as a kludge).
John
Old Apr 13, 2004 | 10:38 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
Thanks for the reply.
I am not sure if these are P/H injectors or what they are for that matter.
This will only affect high-rpm runnings- right?
How can I check all this stuff? Grumpy said something similar in another post about this combo....
Something about changing my drivers???
I had my VEs all set, then I went and changed the cyl volume.
Now it's all lean
I thought if I made the cylinders bigger, it MIGHT ADD fuel...
On the plus side, after an initial stumble this evening it TOOK OFF like I never felt before! WOohooo!
Then it went back to an idle and flooded itself to a stall.
Before the intial stumble was a LEAN fuel condition. It may still be a problem with the PE. I didn't log the accelerations, I was just trying to get my VEs settled.
But now I lost my placement in my BINs.
I got the dates and times mixed up.
Back to the drawing board.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
bjpotter
Oct 4, 2015 07:48 PM
kx3g
Sep 28, 2015 08:14 AM
Damon
Sep 26, 2015 04:29 PM
armybyrd
Sep 15, 2015 06:06 PM
