Help with AE and PE
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
Help with AE and PE
How would I know where to go and what to touch with my setup?
I am asking the collective wisdom of board, and their experience on what to try.
As I am getting close to my VEs, the engine stumbles BAD whether I blip the throttle from an idle or when I am driving.
I have not noticed this to be a problem above ~2000 rpms.
The problem, I think, I need a bigger or sooner/quicker pump shot because I am getting TOO much air (high KPA) with my four barrel TBI.
My PEs are set at 50% - 70% throttle. It's pretty rare when I go beyond 50% even with a blip of the throttle (out of gear). Usually a blip will only yield 30% thorttle.
Where are the AE fuels?
Maybe I will go and look at the commented Super_8dm1.ecu??!!
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
https://www.thirdgen.org/techbb2/sho...hreadid=195745
try here :-)
Always do a search and 99% of the time u will be rewarded.
The stickies are at the top of this page for a reason and that is where this came from..
After that feel free to ask away :-)
Jeremy
try here :-)
Jeremy
Engine: BBC - 408
Transmission: SM465
Thanks for the reply.
I had already read this, but because I am running a TBI instead of a TPI, I am wondering which table to test with first. Hence, I thought the wisdom of the more experienced might chime in with a specific table as it applies to my computer controlled 4 barrel -carb.
I didn't want to go through each one, even though I probably will anyway, and see what works for me. Maybe I am in too much of a hurry to get it mostly together this weekend.
My bad lol
Try searching for A/E and Acceleration Enrichment and keep a look out for tbi related posts
It has been discussed in quite a bit of detail for the TPI(MAF and SD) and the TBI and even for the 6 cyl f bodies..
Car: check
Engine: check
Transmission: check
RBob.
Engine: BBC - 408
Transmission: SM465
Originally posted by RBob
What mask are you running in the '7730?
RBob.
RBob.
After the discussion on the Super_8D. I will be using that one with my correct Volumes, and change my VE. I think I can finish off the volume, and VEs tonight.
Then maybe tonight, or more likely tomorrow morning I will pursue my AEs, and PEs.
That's why I was asking today.
Thanks to any and all for the help.
Car: check
Engine: check
Transmission: check
Heh,
Heh,
The thread pointed out above is how the $8D AE tables operate. That is the area you'll need to work on.
RBob.
Engine: BBC - 408
Transmission: SM465
Sweet!
I found my [b]AE to temp [b] was the same as the AXCN bin => 80 C. It was at .07. I changed this all to .10. Primarily because I noticed my AEs at lower temps (50) the engine responded well with a blip.
It's closer, but not there yet.
Also now with the Super_8Dmv1 it is WAY too rich. I think because the Cylinder volume is being reflected correctly!
YAAAHHHH!!!! :lala:
Time to redo the VE tables.... again.
It's getting there!
YAAAHHHH!!!! :lala:
It's getting there!
