First timer questions.
Old Apr 16, 2004 | 06:16 PM
vwdave's Avatar
Any opinions? Sorry if the data seems weird, but this is out of my Mac Mentor at work, I was writing this down the best I could. This is a 90-92 SD setup.
750 RPM
188* cooling temp sensor
0.51v TPS
2.3 ms injector pulse width
1.7v map voltage
13 iHg MAP
closed loop 0.43v-0.65v O2 voltage
open loop 0.2v-0.3v
Old Apr 17, 2004 | 05:52 AM
vwdave's Avatar
*Bizzump*
Old Apr 17, 2004 | 06:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The open loop O2 loks a tad low (lean), other then that it looks OK.
RBob.
Old Apr 17, 2004 | 06:46 AM
vwdave's Avatar
Thats what I was concerned about. Thinking about bumping the FP a few pounds.
Old Apr 17, 2004 | 06:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
How do the BLM's look? If they are adding fuel it may be better to tweak the MAF tables. If it is lean across the board the fuel pump may be going out.
Has the MAF been descreened and/or gutted? Is there any driveability issues?
RBob.
Old Apr 17, 2004 | 06:53 AM
vwdave's Avatar
Its a SD system. And like I said in my first post, I did all this with a Mac Scanner, so it doesnt display that. I dont have chip tuning stuff yet...
Old Apr 17, 2004 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Oh, yes, you did say SD system. I looked at the sig and went: '89 oh a MAF. I didn't know what you meant by Mac Mentor. . .
RBob.
Old Apr 17, 2004 | 07:19 AM
vwdave's Avatar
A RS with a 350 TPI.
Old Apr 17, 2004 | 08:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In all honesty if the engine is stock and there are no drivability issues I would leave it be. Or,at a minimum look at the fueling at more then idle before making any global changes.
RBob.
Old Apr 17, 2004 | 10:44 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Weird. Most stock bins run rich at idle, lean everywhere else (that I have seen). I think you might want to scan some driving and see whats going on. Time to make a cable and download moates, or tunerpro.
-- Joe
Old Apr 17, 2004 | 11:26 AM
vwdave's Avatar
RBob.
Its not. I just get bad mileage, and I feel there is some power left in it to get out.
When my friend comes back from "vacation" he is going to send me a cable to borrow so I can get some data from you guys.
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
apie2546
Sep 20, 2015 01:03 PM
