Help with eprom, bin and ecu file
I am trying to read an eprom (ABWT).
I tried using winbin with $32 and $32b ecu's.
I am not getting usefull information. It looks like the ecu file is wrong. The fan on/off temps aren't even close.
Can someone open up this bin (a copy can be found here)
http://www.diy-efi.org/gmecm/ecm_info/1227165/
Let me know if I need a different ecu or something else.
thanks
thanks
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I just opened this bin with TunerPro. Looks like the problem is that the bin is 32B, not 32.
Find a 32B ECU file and you'll be fine. If you need one, I've just uploaded it to:
http://moates.net/fileman/index.php?...%20Definitions
32Bv001.zip
32Bv001.zip
KO1
16
Oct 15, 2015 05:00 PM
