T-5 Shift Lights in $8D and 7730 ???
Old Jun 9, 2004 | 08:55 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Anyone know what controls the "SHIFT UP" in the 7730 ECU? I'm using the Super_8d ECU file from Mark Mansur's (Mangus) site, but it only references auto trans TCC stuff. Does anyone know where or what controls this light? Do I need a different ECU file for my TunerPro RT?
Sure hope someone can help me out on this.....
Have a Great Day!!!
- Vern
Old Jun 9, 2004 | 11:04 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Your going to need a copy of the 730 hac from ecmguy's website and an understanding of how to read the code and modify the hex..
To my knowledge no one has made the shift lite stuff a option in any of the editing programs
later
JEremy
Old Jun 9, 2004 | 10:44 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Do you use Tunercat at all? They had the $32b shift light tables for me when I asked them last week for it. There were 3 tables in there for it.
Old Jun 9, 2004 | 11:05 PM
vernw's Avatar
Unfortunately, no.
I've got Datamaster and a licensed copy of TunerPro RT to go with my Moates Flash-N-Burn.
Sounds like I may have to buy TunerCat as well if I want to get my shift light back, doesn't it? What kind of capabilities did you get with this info from them?
- Vern
Old Jun 9, 2004 | 11:08 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
What BCC is the bin you're using?
Old Jun 10, 2004 | 11:58 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Previously,
I thought the Auto trans bit "not " being set would allow use of the shift light (on another pin) and would disable or inversly actuate the TCC solenoid output (undesirable with auto installed).
I seem to remember this from a previous post.
Just curious.
Old Jun 11, 2004 | 09:06 PM
scorp508's Avatar
Car: Corvettes
3 Tables
Shift Light On % TPS Threshold vs. RPM
Shift Light Off % TPS Threshold vs. RPM
Shift Light On Delay Time vs. RPM
Old Jun 12, 2004 | 09:20 PM
onebinky's Avatar
Originally posted by scorp508
3 Tables
IIRC, the 32B mask only works with the MAF setup. I don't think it can replace his $8D without converting from SD
Old Jun 12, 2004 | 10:24 PM
scorp508's Avatar
Car: Corvettes
Obviously, but perhaps $8D has these types of tables in it too. Nobody I knew knew these $32b ones existed until I asked TC.
Old Jun 13, 2004 | 12:38 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If your running the Super AUJP bin, that is an auto bin so it is not going to work right. The shift light on the ECM is the same pin that is used for the TC lockup so the ECM will probably light your shift light everytime it wants to lock the TC. You should start with a manual car's bin.
Old Jun 13, 2004 | 08:18 AM
JP86SS's Avatar
Pins are different
Actually Iroc, the pins are different on the 730.
F6 is the TCC output
F1 is the Shift light output.
I think the output would still work with the bit disabled.
(see above)
I don't know all of the code to know what else goes with it.
The TCC parameters "may" operate it, I'm not sure.
Old Jun 14, 2004 | 08:02 AM
vernw's Avatar
Well, I'm going with the AXYC bin that GM superceded my stock bin with back in '92 when doing an all day tuning session in the next day or so, so we'll see how that works out (both performance and shift light wise). Sure wish I had the code like scorp508 has in his 32B bin in my $8D (or if it's there, knew where it was). Will let everyone know how that comes out.
Thanks for all the replies, I can tell I've still got a lot to learn. Have a Great Day!!!!
- Vern
Old Jun 16, 2004 | 03:12 PM
vernw's Avatar
Using this BIN (which is for a manual transmission), my shift light is operational again. Thanks for the help!
- Vern
Old Jun 17, 2004 | 11:53 AM
scorp508's Avatar
Car: Corvettes
That is great news! Makes ya' wonder what changed in the program between the two.
Old Jun 17, 2004 | 11:56 AM
vernw's Avatar
Has anyone come up with an ECU for $8D file that makes the operation of the shift light "adjustable/tuneable"?
Old Jun 19, 2004 | 02:31 AM
elohssa's Avatar
Car: 1992 T/A convertible
Engine: LB9
I asked the Tunercat guy's about this awhile ago and they said it was unavailable for 8D because they have used up all 99 of the available areas for constants in the current version of the software but that it will be implemented in the next update.
Old Jun 19, 2004 | 08:15 AM
vernw's Avatar
Did they give you any indication of when that next update might be available? I just purchased Tunercat for the $8D for my DIY stuff on my 383. TC has a few features I couldn't find in Datamaster. so I'm going to use TC instead. This will be a nice add-on feature to my DIY efforts on this car.
Have a Great Weekend!
- Vern
Old Jun 19, 2004 | 09:20 AM
11sORbust's Avatar
I knew, so did anyone that has read the hack. In fact, I'm planning on adding the tables so they can control whatever I want
Old Jun 19, 2004 | 08:41 PM
JP84Z430HP's Avatar
Car: 84 Z28
Would it be possible to use the shift light ouput to activate NOS? I'm NOT planning on running NOS, but maybe a good idea for someone that is? I haven't looked at the hac to see what's involved in the shift light stuff, since I have no need, just throwing around ideas here.....
Old Jun 25, 2004 | 07:36 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Now I'm fairly new to this, and have no experience with the actual coding yet (I've only played around a wee bit in TunerPRO using 8d_v03 and Super AUJP) so forgive me if this is blatantly wrong, but if you're setting up an ECU for a manual car anyway, you wouldn't need the TCC constants. Why not put the shiftlight constants in their place? In 8d_v03 that's 7 constants that are just taking up space (for a stickshift car anyway.)
Old Jun 26, 2004 | 01:31 PM
scorp508's Avatar
Car: Corvettes
Well good for you and them then.
Armored91Camaro
Aug 12, 2015 09:41 AM
BIG_MODS
Jan 4, 2012 05:50 AM
elesone
28
Nov 17, 2011 12:10 PM
ls1>*
Exterior Parts for Sale
24
Apr 9, 2009 10:16 PM
ttypecamaro
Apr 3, 2006 10:30 AM
