Random Stall Out (TBI)
Old Jun 12, 2004 | 08:18 PM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
I took the beast out for a long highway run today and was plagued with stalling problems. It seemed to occur randomly and could not be duplicated on demand. Any RPM, and speed; it didn't matter. When ever it felt like stalling, it would stall. It felt just like the fuel pump suddenly quiting. However, being that I have a manual transmission, if I left it in gear it would restart and it could keep going a little further. It made for a very jerky ride.
It seems that I'm suddenly losing spark or fuel but I can't tell which. The ALDL data doesn't show anything suspicious so I'm assuming it might indicate that it's a fuel problem. The fuel pump and filter are brand spankin' new so I kinda doubt it's the pump or filter. Perhaps the fuel pump relay? The relay I'm using is a junk yard special. However, I've never seen a relay go out intermittently. Got any pointers?
Old Jun 12, 2004 | 09:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Check the resistance of the injectors. Much lower then 1.2 and they be drawing enough current to overheat the injector drivers. I saw the same thing on a 730 port setup. But, there still can be something else, ie ignition module. The ALD stuff will tell you what's being commanded, not what's actual other then the O2.
Old Jun 14, 2004 | 08:48 AM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
Resistance seems fine at 1.6 each. The ign module is less than 500 miles old but it wouldn't be too surprising for it to be bad already. I'm using a home converted 4 pin to 7 pin HEI. Yesterday I bought a new 7 pin HEI (comes with the module), it should arrive in a week or so. I'm also going to swap out the fuel pump relay and the ECM. I have a spare ECM so that won't hurt my wallet.
Old Jun 19, 2004 | 04:50 PM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
Update:
Looks like this problem might be related to battery voltage. I've noticed that my battery voltage starts out, when cold, around 14 volts. Then, after driving around a while, the battery voltage slowly decreases to around 12.4 volts and then the engine dies. Is this an alternator problem or is the decrease in voltage normal?
Old Jun 19, 2004 | 05:57 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yes, there sounds to be a charging system problem.
12.4 is kinda high to have an ecm shut off.
Start with the obvious, belt tension, battery cables, might even put a Volt Meter on the battery itself to see what the voltage is at the posts. There maybe a slight drop, but not too severe.
Old Jun 20, 2004 | 09:48 PM
funstick's Avatar
get your hands on an oscilliscope and check the alternator for a/c ripple. Sounds like the diode might be overheating during cruise modes. Otherthings like a bad coil can cuase this. I see lot of GM coils for HEI constanlty crack the towers and cuase all sort of nightmarish hard to find driveability woes. If in doubt dump some water on the igintion coil and wire and checfk for arcing out.
Old Aug 22, 2007 | 09:03 PM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
Re: Random Stall Out (TBI)
I was going back through my old posts and figured that it might be helpful to post the solution to this problem.
The stalling turned out to be a result of a bad ground.
Old Aug 23, 2007 | 12:03 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Brennanw
Which one - on the back of the driver side head or the sensor ground???
//RF
Old Aug 23, 2007 | 07:31 PM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
Originally Posted by RFmaster
Brennanw
//RF
This isn't a stock application. I'm using a Painless harness for my EFI and the system is installed in a 1956 ****** truck. I had all of my ground wires tied into a single heavy gauge ground wire that was molded into the lead (as in Pb) portion of my negative battery cable. Well, it turned out the the heavy gauge copper wire pulled loose inside of the lead (Pb) and was causing intermittent ground failures.
amcnellis
Sep 16, 2015 04:16 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Jk_Under
Sep 8, 2015 08:13 AM
rjcme
Sep 5, 2015 01:23 PM
