Why is my ECU not learning?
Old Jun 19, 2004 | 08:58 PM
andy330hp's Avatar
I'm setting up a TBI system on my father's truck using a 16197427 ECU. Closed loop and BL appear to be functioning fine. I'm using a basic autoXray scan tool. When I key off and key back on, the BL values all appear to have reset!!
The most obvious cause I could think of was that the b+ was wired instead to ignition, but this is not the case. B+ is wired correctly, as is the ignition +.
I spoke to my coworker jeremy (RednGold86Z), and he mentioned seeing a similar problem in his GTA which has a '165 ecu I believe.
What is the common problem in both instances that is keeping our ECU's from storing on powerdown? Are some ECU's like that from the factory? Has ANYBODY else seen this?
Old Jun 19, 2004 | 09:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Why is my ECU not learning?
I'm pretty sure my 7060, 91 TBI PCM is that way.
When I run closed loop, I'm generally pretty close to 128s so it's not an issue, in that case.
Rocket-Doc
Nov 14, 2015 02:08 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
drumstixer
Sep 29, 2015 03:02 PM
mfp189
Sep 27, 2015 09:25 AM
