Afr Tuner
Old Aug 4, 2004 | 12:06 AM
rightfoot's Avatar
Car: it is broken
Engine: 327 in 89 block tpi
Transmission: 200r4
Afr Tuner
help anyone!
I can't get it to open a bin.
shows an error:
"error in frmMain. OpenBinaryFile
error number: 429
activeX component can't create object
error source afr tuner"
I have installed the oxc files and registered them
as well as a few other activeX controls I stumbled onto
also deleted the afr tuner files and reinstalled
this is the second week without any progress.
can anyone point me in the right direction?
even a hint would be welcome.
Geoff
win98se
Old Aug 5, 2004 | 09:56 AM
rightfoot's Avatar
Car: it is broken
Transmission: 200r4
bump
TTT
Old Aug 10, 2004 | 11:17 AM
rightfoot's Avatar
Car: it is broken
Transmission: 200r4
bump II
TTT again
Old Aug 10, 2004 | 07:11 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
What's afr tuner?
Old Aug 11, 2004 | 12:15 AM
rightfoot's Avatar
Car: it is broken
Transmission: 200r4
AFR tuner
https://www.thirdgen.org/techbb2/sho...ight=AFR+tuner
from the sound of it, it will help alot with part thorttle tuning.
I just haven't been able to get it to run.
has to be something I am missing, any help would be apreciated.
Geoff
Old Aug 11, 2004 | 06:50 AM
VetNutJim's Avatar
Probably your best bet is to email TRAXION.
I scanned through the link post and here's what you may want to check....
Did you copy the ocx's to THIS DIRECTORY?
c:\windows\system\
(shouldn't matter what directory you put them in as long as you registered them with REgsvr32)
Are these files "REGISTERED" on your computer. IOW did you register them using Regsvr32?
'comdlg32.ocx'
'msflxgrd.ocx'
'msflxgrd.ocx'
Are there any SP's (Service Packs) for your OS that you have NOT installed?
Good luck with it.
Old Aug 11, 2004 | 02:39 PM
rightfoot's Avatar
Car: it is broken
Transmission: 200r4
yes, windows reported success for both
Old Aug 11, 2004 | 03:41 PM
11sORbust's Avatar
Sorry bud, the program is not for part throttle. Might want to try VE master for that.....
Old Aug 12, 2004 | 12:35 AM
rightfoot's Avatar
Car: it is broken
Transmission: 200r4
Yea I know , I had been reading about VE master guess it was still fresh .
Geoff
still can't get afr tuner to run thou.
Old Nov 25, 2007 | 08:37 AM
cooper91's Avatar
Re: Afr Tuner
Newbie here, just getting my first project started.
Has anyone got a solution to this? i've tried to run AFRTuner on 2 different XP machines with the same error.
Thanks in advance.
Old Nov 25, 2007 | 05:35 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Re: Afr Tuner
I had the same experience with AFR tuner as well.
I just eventually gave up.
Old Nov 25, 2007 | 09:48 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Re: Afr Tuner
Took all of two minutes to find this thread by doing an advanced search.
https://www.thirdgen.org/forums/diy-...fr#post3471713
I can vouch for the fact this file is clean of anything nasty. But to be safe use your anti-virus program to check it. Just run it and it will automatically install the files for you.
Old Nov 25, 2007 | 10:22 PM
Car: 1991 Z28
Re: Afr Tuner
Wawawewah! Very Nicce!
Finally it works.
Thank you
Old Nov 25, 2007 | 10:37 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Re: Afr Tuner
Finally it works.
Thank you
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
tuningnewb
Sep 23, 2015 07:06 PM
