data error
Old Aug 29, 2004 | 10:14 PM
11sORbust's Avatar
data error
I was logging some data with datamaster. It showed a data error. Not sure what that means. Maybe you could help me understand what is going on....
Old Aug 30, 2004 | 09:19 AM
jonarotz's Avatar
Car: 91 Z28
I get the same thing. I have no clue what it means. The chime gets annoying doesn't it.
Any body have any ideas?
Old Aug 30, 2004 | 11:15 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Anything red in the DTC window?
Any trouble code seen there will throw the error, this looks like a communication drop out or a bad chunk of data.
Could also be an interference from something electrical near the harness.
Maybe a loose connection at the ALDL or play with the comm settings to get it to go away.
Old Aug 30, 2004 | 11:52 AM
11sORbust's Avatar
Nope, and the connection was good. I just don't get it. When the mouse pointer is over the data error box it says "engine data checksum error".
Old Aug 30, 2004 | 10:57 PM
11sORbust's Avatar
That sucks! I figured someone would know what that error means
Old Aug 31, 2004 | 04:19 PM
11sORbust's Avatar
makes me wonder if the tps is sticking. I checked another log file. At the time of that error, the tps % was 100 and the tps voltage was 3.73 .....Guess I'll check into that and let you guys know
Old Aug 31, 2004 | 08:11 PM
jonarotz's Avatar
Car: 91 Z28
When it does it to me my knock counts shot way up for a split second and then returned to normal.
I think it is just a fluke in the data stream, maybe some interference of some sort.
Old Aug 31, 2004 | 08:57 PM
11sORbust's Avatar
That's kind of what I thought but kind of got confused with the checksum error, do not know if the error is in the prom or data stream
Falcon50
Aug 22, 2020 03:26 PM
bjpotter
Oct 4, 2015 07:48 PM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
