knock retard
Old Aug 30, 2004 | 07:01 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
knock retard
Hey guys. My '87 is getting about 5 Degrees of knock retard upon opening up the throttle all the way. I don't see it anywhere else but when I mash the throttle...Any ideas. Also the O2mv are at 940mv at WOT and the AFR is 12.4. Does this mean it's rich??? It seemed to run better at about 880mv or so before I upgraded my 32 bin to the 6E bin.
Using tunerpro I have the PE spark advance set to 1.05 from 1200-4800 rpm. At the 4000/192 spot I am running 27D,4400 26D, and at the 4400-4800/208 spot 28D and 30D respectively.
I'm running the 165ecm and the Arap 6E bin. I've taken some timing out and have not messed around with the PE very much if at all.
Thanks,
Chris
Old Aug 31, 2004 | 07:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You may want to check the PE SA added, 10 degrees in one range of RPM.
Did you zero out the ALDL SA adder value? If the 10K resistor is in place this SA is added.
Else back down the SA until it stops knocking.
RBob.
Old Aug 31, 2004 | 08:16 AM
sparks454's Avatar
Car: 1987 GTA
I'm not sure what the aldl SA adder is, but there is not a 10k in place across A and B when the car is running. It's there upon startup to get the data going and then removed.
In the PE vs. SA there is 1.05D in the 4 cells from 1200rpm to 4800rpm. There was 9.05D in the 3200rpm cell but that was reduced to 1.05D a while back...
So you are saying that the SA in the SA vs. RPM table should be reduced????Why am I not seeing knock retard then anywhere else. It's only when the throttle is mashed down. Once it's passed that initial jump in rpm, and while the throttle is held open during acceleration, there is no more knock retard. It's only for that first second or two that I see it....
Old Aug 31, 2004 | 08:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Burst knock retard. Some masks have a short SA reduction with a sudden opening of the throttle. Intended just for this problem.
May not be able to get rid of it without going to a higher octane fuel.
Then again what is the AFR doing for that instant. It may be going lean which will also contribute to the problem. Will need a WB to see that.
Or it may be that the SA isn't being tapered out fast enough. In the LV8 vs RPM table how fast does the SA taper out to the high LV8 side.
Is the transmission downshifting too?
RBob.
(see the problem with remote tuning. . . )
Old Aug 31, 2004 | 05:52 PM
Desert86Roc's Avatar
Are there any other conditions that would cause the ECM to pull timing other than knock counts incrementing? I have an issue where during a run, the timing is getting yanked, but no knock is occuring.
Old Sep 1, 2004 | 05:23 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
$8D also have this SA reduction?
-Beppe-
Old Sep 1, 2004 | 06:51 AM
sparks454's Avatar
Car: 1987 GTA
47.11 47.11 47.11 44.30 40.43 39.02 37.97 35.16 33.05 32.34 32.34 32.34
47.11 47.11 47.11 44.30 40.43 39.02 37.97 33.05 30.94 29.88 29.88 28.13
47.11 47.11 47.11 44.30 40.43 39.02 37.97 30.94 27.07 25.66 25.66 25.66
47.11 47.11 47.11 44.30 40.43 39.02 37.97 30.94 26.02 23.91 23.91 23.91
47.11 47.11 47.11 45.70 41.84 41.13 37.97 30.94 26.02 22.85 22.85 22.85
47.81 47.81 47.81 46.41 46.06 43.95 42.89 34.10 27.07 24.96 22.85 21.09
47.81 47.81 47.81 46.41 46.06 45.70 43.24 39.02 31.99 27.07 23.91 22.15
47.81 47.81 47.81 46.41 46.06 45.70 43.24 37.97 33.05 27.07 23.91 22.15
47.81 47.81 47.81 46.41 46.06 43.95 43.24 36.91 34.10 27.07 23.91 22.15
46.06 46.06 46.06 45.00 45.35 43.95 40.08 35.86 34.10 27.07 24.96 23.91
43.95 43.95 43.95 42.89 41.84 41.13 37.97 33.05 28.83 27.07 23.20 21.09
41.13 41.13 41.13 41.13 40.08 39.02 36.91 32.34 29.88 26.02 22.85 20.39
29.88 34.81 40.08 40.08 40.08 35.86 35.86 31.99 29.88 26.02 22.15 20.04
20.04 29.88 40.08 36.91 35.86 31.99 29.18 28.13 26.02 23.91 20.04 20.04
20.04 20.04 29.88 29.88 29.88 29.88 27.07 26.02 23.91 20.04 20.04 20.04
20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04
Do you know if the ARAP 6E has this burst knock retard so I don't keep trying to fix something that might not be broken???
Above is my SA table. It's the only one that corresponds to the LV8 vs. RPM that I can see. At 3000-3200 rpm 7D of retard, 3200-3500 about 2D of retard. I keep taking timing out, but the knock retard still remains. The car is not downshifting. This is when manually held in gear and opened up. I only run 92 octane or higher and there should not be any problem with 9.75:1 or less compression. Also running the T/F 23degree heads. At these two points there is 23-25 degree SA with reference to TDC using tunerpro.
-8.60 6400
-8.60 6000
-8.60 5600
-8.60 5200
-8.60 4800
-8.60 4400
-8.60 4000
-8.60 3600
-0.00 3200
6.25 2800
6.25 2400
6.25 2000
6.25 1600
11.72 1200
11.72 800
11.72 400
11.72 0
This is the PE vs. RPM table. I have not messed with this one too much. If the plugs are pulled they look somewhat rich. The O2 counts at WOT are 920-960mv and the afr at WOT is 12.44. When the gas is mashed the AFR goes to 11.8 for a brief second and then upto 12.44 where it stays until gas is let off. One wire O2 sensor and using the graph in tunerpro this is the data I see. Still looks to rich to me. Cruise mode and idle BL's are 126-132.
Below is the PE vs. SA table.
1.05
1.05
1.05
1.05
0.00
Old Sep 1, 2004 | 07:31 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
If you are using tunerpro then this should help. Download his version of 6E and remember to thank Cobra289.
https://www.thirdgen.org/techbb2/sho...hreadid=256616
Old Sep 1, 2004 | 07:38 AM
sparks454's Avatar
Car: 1987 GTA
Thanks for the info, but I am not running with the 10k in place so there is no 8D added to the SA table.
Old Sep 1, 2004 | 09:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't see any burst knock retard function in the $6E code. Do the plugs any any signs of detonation? Pepper flakes? It may not be true knock. Can you hear any knock.
Another item is the forced knock test. Is it enabled?
RBob.
Old Sep 1, 2004 | 09:55 AM
11sORbust's Avatar
FYI, 90% of knock counts I have encountered has been false.
Old Sep 1, 2004 | 10:00 AM
11sORbust's Avatar
What is that? Could you give me the locations, maf/6e and 8D/730?
Old Sep 1, 2004 | 12:03 PM
sparks454's Avatar
Car: 1987 GTA
I am not sure where to find the forced knock test. No visible or audible signs of detonation. Plugs are 75% on the dark side.
Should I try removing some fuel from the PE vs. RPM table. See previous post......
Old Sep 1, 2004 | 12:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Locations for $6E forced knock test:
Code:
LC236:	.db	  1		; SA increment
LC237:	.db	180		; 90C, (194) MIN COOL TO ENABLE ERR 43
				; CALIB = (Deg C + 40) * 256/192
LC238:	.db	 190		; min LV8 for test enable
LC239:	.db	  71		; Add x Deg Sprk Adv for #43 test
				; CALIB = Deg * 256/45
As far as leaning out WOT AFR, can't say one way or another. . .
RBob.
Old Sep 1, 2004 | 02:09 PM
sparks454's Avatar
Car: 1987 GTA
I have not gotten into code yet, but what in the table you provided needs to modified??
2. what tools do I need to modify that table or line code??
Old Sep 1, 2004 | 04:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To disable the test I would set the enable temperature to max. Change location LC237 to 255.
Use either a hex editor or a bin editor. May need to add that location to the TDF/ECU file.
RBob.
Old Sep 2, 2004 | 12:14 AM
11sORbust's Avatar
Does the 8D mask have this knock test? If so, then do you know where the location is ?
Old Sep 2, 2004 | 07:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes it does, check the malf 43 area. Can disable it the same as the $6E.
RBob.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
383backinblack
Sep 25, 2015 11:31 AM
ericjon262
Sep 11, 2015 06:07 PM
