different useable proms?
Old Sep 9, 2004 | 12:50 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I was having a conversation with a friend the other day, and the question came up of if we could take any prom from a Speed density ecm (other than a 730) and use that chip to burn with if the files were loaded onto it. Is it possible?
Old Sep 9, 2004 | 01:42 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Re: different useable proms?
I'm assuming you're using the word PROM to mean the actual chip, and not the entire MEMCAL. In other words, you're asking if you could recycle EPROMs from other GM applications?
Answer: Sometimes.
Some P4 MEMCALs had to have a 256K chip, some only had a 128K chip. And sometimes GM used 256K chips where only a 128K was needed. So, if you have a '730 and want to run $8D, your donor MEMCAL would need to have a 256K chip.
In reality, I doubt there's much recycling of old GM 27128 or 27256 EPROMs going on, since new ones only cost a few bucks, and compatible flash chips are available that are much more convenient to work with.
I hope that answers your question.
Old Sep 9, 2004 | 12:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
For the most part, yes. We have some spare proms laying around. Maybe we should try it.
Old Sep 10, 2004 | 08:28 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Re: Re: different useable proms?
And AT29C256 EEPROMs are only a few bucks
Old Sep 12, 2004 | 12:20 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Well, will the memcal from another ecm work? I have those laying around also. (spares?)
Old Sep 12, 2004 | 12:57 AM
Dave_Jones's Avatar
It depends. At a minimum, the cylinder select, and ESC stuff has to match up. So, you'd be asking for trouble if trying to use a V6 MEMCAL on a V8, or trying to use a '165 MEMCAL in a '730 or '749, for example.
If you're like me, most of the extra MEMCALs you have lying around came from 4- or 6-cyl apps, which makes them basically useless, if you're intersted in V8 applications.
Old Sep 12, 2004 | 05:55 PM
ben73's Avatar
I was under the imporession that it was ok to use a memcal from a 6 cyl application, as long as the prom had a 8 cyl .bin written to it. Is this incorrect?
Old Sep 12, 2004 | 10:29 PM
Dave_Jones's Avatar
I've tried that a couple of times on the ECM bench, and it's never failed to produce really wierd results. Also have heard of quite a few tuning headaches over the last few years, caused by people trying to do the same on real world apps. There may be some exceptions where it works, but I don't recall ever hearing of any.
Dunno if anyone's developed a workaround -- for the price of a V8 MEMCAL I don't see it being worth the effort.
Old Sep 13, 2004 | 02:47 AM
ben73's Avatar
bummer :-(
Old Sep 13, 2004 | 08:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Yup, I have quite a few from 4 cyl. and v6's. It was worth asking at least. Maybe I could give them away as door prizes or something.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
