VE & Spark Table Graphs, Good???
Old Sep 23, 2004 | 11:38 PM
92GTA's Avatar
After some small tweaking on my VE and spark tables for the first time ever, I came up with the following and wanted to get some feedback on how it looks. In other words, what does yours look like because IMO the spark table looks really weird and not linear like the VE tables are. It just seems to me everything should be nice and smooth and progressive...
Old Sep 24, 2004 | 01:14 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Do you have those in chart form? Or maybe with a graph showing the magnitudes.
Old Sep 24, 2004 | 05:53 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Well your spark table looks similar to mine, I still have some work to do on them, however, they seem to work fine and I have no Knock:
Your VE tables look really flat, However it depends on what you engine wants, still they look flat to me.
Here are mine, tuned with a WB.:
Old Sep 24, 2004 | 08:49 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
How are you guys pulling these out of TunerPro so you can attach them to a post?
Old Sep 24, 2004 | 11:04 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
When you have graph from tunerpro on screen, press print screen key. This copies the screen image to memory. Then go to a graphics program, I use microsoft photodraw, and paste. You could use powerpoint, whatever. Then Crop the image to get rid of the parts of the sceen that you dont what and save as a .jpg Then you could upload the image on the site, or in our cases put it on my homepage server and host it from there.
Old Sep 24, 2004 | 11:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What novass said. Doing an ALT-PrintScreen will only capture the active window. I do the same and paste it into Minisoft's Photo Editor.
RBob.
Old Sep 24, 2004 | 12:50 PM
vernw's Avatar
THANKS!! Works like a charm!
Old Sep 24, 2004 | 01:09 PM
92GTA's Avatar
Yeah my VE table numbers are very low because I'm running 30# injectors in an engine that really only needs 22# or 24# at the most. I had to tune it all down so I wasn't rich as a pig. Once the SC'er goes on thing will be different, especially in the upper VE range...
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
