Do chips wear out or take a memory?
Old Sep 24, 2004 | 09:23 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have been having trouble reprogramming my stock chips for my 1988 Firebird and I was wondering if they wear out or take a memory? The first few times I erased them and reprogrammed them everything seemed fine but the more I erase them and reprogram them the harder it is to get them to program. It some times takes me 10 tries to get the chip to program after it is erased. The pocket programmer II that I use says the chips are erased but they will either not program or not verify to the buffer. I then have to erase the chip again and start over, sometimes this process will be repeated 10 times before I get the chip to program. Is there something I am doing wrong or are the chips taking a memory that is hard to erase? The chips I am using are the 27C128 style which are UV erasable.
Related to that subject are there any chips that I can substitute for the 27C128 chip that are electrically erasable and programable from my pocket programmer II, I would think an electrically erasable chip would be faster to reprogram.
Thanks for any help.
Old Sep 24, 2004 | 10:02 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, I dont think so, but I guess they could go bad being subjected to a static change. This might happen to one Eprom but not all of them. maybe you are doing something wrong, I would not know what.
I started with 4 Eproms and perhaps programmed 120 times with my Pocket Programming. I never set my Eproms down on a metalic surface and I am not insulated from the carpet. My Eproms will erase in about 10 minutes and I can program them right away.
Sorry I'm not being much help here.
Old Sep 25, 2004 | 02:06 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I think wiht some small changes or maybe with no changes at all something like a 28C256 EEPROM could be used. Dont quote me on that. Check the pinouts. Grounding one pin should allow you to use the chip in its place.
Old Sep 25, 2004 | 05:30 AM
ben73's Avatar
You can use AT29c256's, just double stack the bin.
Much easier than erasing eproms!
Old Sep 25, 2004 | 01:05 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
In some obscure web site they mentioned the last 27128 type eprom chip was manufactured in like 1985.
Might just forget the *E* stuff all together and get some of the EEPROM 256s.
Old Sep 25, 2004 | 07:50 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Thanks for the help
Old Sep 25, 2004 | 09:06 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
There was a post a while back from Grumpy that said you should wait a little after the key is turned off before removing the chip.
I'm not sure exactly what the technical end of it was about, but the chips would go bad after doing it more than a few times.
I tried to search on it but could find the post. Maybe someone will chime in.
Not sure if it applies to UV types but IIRC, it wasn't good to do and made the chip fail later than sooner so it would be hard to find what happened.
Old Sep 25, 2004 | 09:52 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
The reason is that the ECM stays powered for a few (my 1227165 is about 12) seconds after the key is turned off. This allows things such as MAF burnoff, IAC reset, etc.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Vintageracer
Sep 24, 2017 12:34 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
