pocket programmerII
Old Sep 27, 2004 | 12:42 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
pocket programmerII
to use pocket pro 2
1st i click 2732
then i load buffer
then i click program devise.
After i do this it says device did not programm
what am i dooing wrong.
also befor i did this i did a blank check and it was blank
-Walter
Old Sep 27, 2004 | 01:29 PM
Ronny's Avatar
did it give error message? chip in backwards? pp2 attached to 12 V source (i always forget)? tried a different chip? is the chip locked(i forget) in pp2?
Old Sep 27, 2004 | 04:26 PM
ben73's Avatar
What type of eproms are you trying to program, 2732 or 2732A, have a close look at the markings on the chip?
These old eproms can be dodgy at times.. I have about 40 of them and only about 1/2 will accept a new tune.
Do a search on '28c64' and you will find a thread explaining how to use a EEprom in place of a 2732 Eprom. This is how I do it and its MUCH easier. No more UV erasing ;-)
Old Sep 27, 2004 | 08:45 PM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
that must be the problem i was trying to use 2716 i didnt know there was a difference. whats better 2732 or 2732A? is there a big difference. im gonna buy these TMS 2732A-17JL will they work?
Old Sep 27, 2004 | 09:46 PM
ben73's Avatar
Neither 2732 or 2732A is better.
They have different programming voltages.
From memory, 2732 is 25v and the 2732A is 21volts.
If you try to program a 2732A at 25v, you will likely permanently kill it and if you try to write a 2732 at 21v, it just won't work..
You MUST select the right type of eprom in the software!!
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
anesthes
Sep 21, 2015 10:24 AM
Glowsock
Sep 11, 2015 11:09 PM
