Calculating DRP?
Old Oct 4, 2004 | 11:41 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Calculating DRP?
How is the DRP value calculated?
Old Oct 4, 2004 | 01:52 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
ok, let me see if i did this right, this should be how its done.
16 bit counter, provides 65536 bit counts per second. to get DRP, you must know your rpm, so the conversion is from minutes, so you've got
65536counts/sec X 60 sec/min X 1revolution/4 ign events(8cyl)=
983040/RPM=DRP for 8 cylinder.
1310720/RPM=DRP for 6 cylinder.
this is based on 32B/6E stuff.
Old Oct 5, 2004 | 11:19 AM
Doward's Avatar
Hmm... now I gotta wonder which is right -
TunerCats got back to me, and told me it's 60/3*rpm for the V6, or 60/4*rpm for the V8....
Who's correct?
Old Oct 5, 2004 | 12:27 PM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
You guessed it, both are right!!!
jwscab shows DRP in units of timer "counts". (And, if I might add, in a very nice dimensional analysis format!)
TunerCat shows DRP in "seconds". To be clear, the equation for V8 is : 60/(4*RPM). It is NOT (60/4)*RPM. The RPM term needs to be in the denominator. As RPM increases, the time between pulses decreases.
To convert between the two, multiply/divide by 65536 counts per second.
jwscab's Avatar
Engine: Many
thats part of the formula i gave you. I dunno if he's not taking into account the counter parameter. I also don't know how the code you are looking at does it, what kind of value do you get for a drp running that v-6 code? say at like 2000 rpm?
Old Oct 5, 2004 | 01:57 PM
Doward's Avatar
60/(3*2000) = .01 seconds. Could also be, that I'm looking @ DRP as Distributor Refernce Period, not Reference Pulses - I'm using it in conjunction with the MAF values to figure LV8 in the 302 ecu.
Old Oct 5, 2004 | 03:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Itll be the dist. reference period, or the time in between each recieved reference pulse/cylinder firing. The actual time in seconds is the period multiplied by 15.26 &#181sec/bit.
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
fasteddi
Sep 2, 2015 10:29 AM
Scott 88 GTA
Mar 19, 2001 06:11 PM
