165-730 Adapter ?
Old Oct 4, 2004 | 02:54 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
165-730 Adapter ?
Alright I upgraded from a 870'-165 not to long ago. I have found that I have a bad MAF and rather than replace the maf I am going to build a adapter Per Mike Davis Site.http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Well I tried to unsolder a ECM Pin Header from the old 870 with no luck, Does anyone have a Unsoldered Pin header from a 165 or equivlent that they want to get rid of.
I will give the 870 which still has header Soldered to some one to replace the Header the send me.
Old Oct 4, 2004 | 03:01 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
are you going to permanently change the ecm? if so, you could repin the connectors to a 730, rather than make an adapter harness, will be more reliable, and only cost the price of the '730 connectors. Its also easy enough to swap back, as long as you don't want to swap in like 10 minutes.
Old Oct 4, 2004 | 03:20 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Well I want to make the adapter harness Because I don't Think my 1985 Harness will Take another Repinning With out a furneral. Plus I will have a 165' to Run the car in a Emergency should something happen to the 730. Plus this will allow me to lengthen the existing harness. The adapter just makes more sense to me because I will have flexability to go where I need to.
Old Oct 4, 2004 | 04:25 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
John at Casper's usually has them in stock.
Casper's Electronics Inc.
1333 Wilhem Rd., Mundelein, IL 60060
1 (847) 247 0484
1 (847) 247 0483 FAX
Old Oct 4, 2004 | 05:04 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Thanks Grumpy. I found the website at http://www.casperselectronics.com/ but I couldn't find the ECM Headers online.
Guess I will have to call them, you have any idea how much they cost off the top of your head, If not Please ask Doc.
Old Oct 4, 2004 | 11:05 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Here's how I made my conversion harness. It's housed in my old 165 box. Don't mind the D-sub connectors. The left is pinned for a 730, the right for a 749 -- so I can switch back & forth without repinning.
Old Oct 5, 2004 | 01:02 AM
Morley's Avatar
All you really need are header pins...get them from Mouser.com or Digikey
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
romcjr
Sep 17, 2015 05:18 PM
