Anyone get this Tuner Pro Error?
Old Oct 22, 2004 | 12:23 AM
92GTA's Avatar
Certain bin files when I try and open them, say for example the S_AUJP, I get an error box that reads this:
Then to read the file I have to re-select the .ecu file. No matter what I try like removing the option to load last ecu file on startup, or load last bin on startup, or reselect the ecu file then try opening the file, I still get the same error. I get it with different bins too, like I also get this with a $58 bin. Most bins I don't but some I do.
What's going on?
Tuner Pro RT registered, XP Pro.
Old Oct 22, 2004 | 12:54 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Heh. Look at that, I can't type none too good. ("Could open default definition" - should be "Couldn't).
The file you specified to open the bin (the ECU file) in preferences is no longer there. Go to preferences, select "default definitions" tab, and re-browse to the default definition for the mask of the bin you attempted to open.
If that fails, delete the TunerProSettings.dat file in the TunerPro directory and re-open TunerPro.
M
Old Oct 22, 2004 | 01:26 AM
92GTA's Avatar
Ummm, nope:
Deleting the TunerProSettings.dat file did the trick though.
Any idea what causes that and why you need to delete that file? I'm just curious...
Old Oct 22, 2004 | 01:33 AM
Mangus's Avatar
Transmission: T5WC
Ummmm, yup. Thats why I gave you the second option. ;-)
Sure, I know why. Somehow your settings file got corrupt - specifically, the portion of the file that tells TunerPro what ECU to open when it encounters a specific mask byte. The crash you saw was likely TunerPro shutting itself down (unhandled exception) as a result of trying to do work on a file or at a path that doesn't exist.
Glad you got it sorted out.
Old Oct 22, 2004 | 01:35 AM
Mangus's Avatar
Transmission: T5WC
And we truly are sorry for the inconvenience. (Just like the Crash report says).
Old Oct 22, 2004 | 01:37 AM
92GTA's Avatar
Hey I blame windows and microsoft too. I'm sure if you had written it for linux and I was running it on my Debian rig I'd never have any problems right
Old Oct 22, 2004 | 01:53 AM
Mangus's Avatar
Transmission: T5WC
You don't know what you're saying.
Old Oct 22, 2004 | 12:22 PM
92GTA's Avatar
It was a joke Microsoft = Instability, TunerPro = Perfect....
Sorry I guess it was in bad taste...
Old Oct 22, 2004 | 01:03 PM
Mangus's Avatar
Transmission: T5WC
I know... my reply was actually a joke (very inside) too. You're cool, no worries.
Old Oct 22, 2004 | 01:09 PM
92GTA's Avatar
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
