building aldl cable and "poof"
"Poof" is not good.
I'm building the 1 transistor, external power source to cig. lighter unit.
When I plugged it in, a brief few seconds passed and the wire to the cig. lighter started smoking! Needless to say, test over.
o.k. How heavy does the wire have to be at this point and, do I have only the positive lead going into the cig. lighter adapter?
This is taking longer than I thought
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Sorry, just kidding of course.
He's right. There should be very little current draw. I'd expect you could use 22 gauge without any problem if you wanted to. Must have had something wired up backwards or a short. I'd say just try again and double check it.
Car: Which one?
Engine: 355
Transmission: 465
Can't you just tap off of your fuse panel?
Cigarette wiring seems to be a bad spot in GM vehicles, the fuse panels all have empty accessory terminals do they not?
wigmobile
Feb 26, 2025 02:56 PM
