TCC lockup tuning
Old Nov 1, 2004 | 12:53 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
TCC lockup tuning
Okay, I'm trying to get a little bit better gas mileage out of her while driving 40-55ish MPH (speeds I typically drive at while going to the girlfriend's house).
Car is basically stock at the current point in time. What would be the ideal TCC lockup conditions? I'm looking at this purely from a gas mileage standpoint, performance isn't on my mind now that winter is coming.
Working on setting the highway mode stuff a bit as well. Is it safe to enable the highway spark mode at 1000RPM instead of the stock 1600RPM? At 40MPH, I'm right at 1000RPM (usually driving a little above that though). Should I make highway spark/fuel tables more aggressive as well?
Old Nov 1, 2004 | 05:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I wouldn't add SA unless it is required for a lean mixture. At that low an RPM (1,000) I don't thnk the engine would like it.
For mileage at 40 MPH, you might be better off in 3rd gear (D) with the TCC locked. The engine should be more efficent at a RPM a little higher then 1,000.
RBob.
Old Nov 1, 2004 | 11:46 PM
Car: 1997 Corvette
Hmmm interesting. Thanks I'll look into it. I'll be making the drive again tomorrow so I'll mess with a few things and see how it is driving in 3rd.
Old Nov 2, 2004 | 12:51 AM
Car: 1997 Corvette
I'm a bit confused, it seems as if the lock/unlock tables contradict each other.
Say for example at 36mph...
It locks if TPS is less than 44%.
It unlocks if TPS is more than 20%.
So if I'm cruising at 36mph and step on the gas at 30% throttle, the converter unlocks (being greater than 20% TPS), but immediately its going to want to lock again because it is under 44% throttle. This is looking at it one table at a time as the computer does (when locked, it looks at unlock table, and when unlocked, it looks at lock table). Looks like there are some grey areas like this that will cause it to repeatedly lock/unlock in a loop...
Am I not grasping this concept correctly, or did GM stupidly program these cars? I'm leaning toward the former, but I'd like to know where I'm missing. I don't know what to change to get better mileage if I'm just cruising around nice and easy on the throttle at between 35-50mph (1250ish to 1800ish in 3rd gear)..
Old Nov 2, 2004 | 06:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The tables are probably reversed. I've found some of the hacs, ecus, tdfs. . . also have them reversed. Switch the tables so they make sense and that is correct.
RBob.
Old Nov 2, 2004 | 06:48 AM
Car: 1997 Corvette
Wait, switch the values in the tables or just switch the names of the tables?
Old Nov 2, 2004 | 07:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just the titles, data is OK.
RBob.
Old Nov 2, 2004 | 07:08 AM
Car: 1997 Corvette
Ah okay, thanks a lot. I'll do that and from there for the table settings
Old Nov 3, 2004 | 08:27 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
i have noticed this with using tunerpro. a 6E ecu has the tables reversed. but using a 32b ecu the numbers and table headings are correct and make sense. so the table numbers are correct but the headings are incorrect? or do you need to reverse the numbers from the 2 tables? can someone please verify which is correct?
Old Nov 3, 2004 | 01:32 PM
Car: 1997 Corvette
As mentioned above, switch the table headings.
Old Nov 3, 2004 | 01:43 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Early Tunercat $8d's were like that also.(been fixed for well over a yr)
I still have the pretty picture Rbob drew for me on that one! lol Thought I was going nuts!
later
Jeremy
Zell1luk
Sep 29, 2015 10:36 AM
