MAF to MAP plug wires, need help on 1988 Firebird
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
Which color wires from the original MAF sensor go to which numbered terminals on a MAP plug? I switched mine, and it's wrong, and I can't remember which one goes to which, anyone who has done the conversion, can you tell me which one's go where? thanks.
PJ
PJ
Car: check
Engine: check
Transmission: check
Re: MAF to MAP plug wires, need help on 1988 Firebird
PJ
PJ
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Ed did a bang up job describing this swap.
RBob.
Car: 1988 Formula
I have looked through his site, but can't seem to find what I"m looking for. If anyone who has done the maf to map conversion could post on which color wires go to which numbered terminal on the new map plug, that would be great.
Car: 1988 Formula
Can anyone help me out? I still cannot find a good picture of what I'm looking for. If anyone who has done the swap could tell me which color wire goes to which lettered terminal on the map plug, that would be great.
pj
pj
Car: 1987 Z28 Convertible
Transmission: 5-speed
Lucky I made my MAF to MAP harness plug and play. I was able to remove and check it easily:
MAF A = MAP A
MAF B = MAP C
MAF C = MAP B
MAF D = Not Used
MAF E = Not Used
MAF A = MAP A
MAF B = MAP C
MAF C = MAP B
MAF D = Not Used
MAF E = Not Used
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
