Something odd
Old Dec 10, 2004 | 12:06 AM
88Z's Avatar
88Z
Car: 88 Iroc
Something odd
I just scanned the chip i was using in my car. Turns out, the guy who burned it didn't double the bin for the bigger atmel chip. The only values were burned into the second half of the chip. What kind of effects would this have on my car exactly?
Old Dec 10, 2004 | 06:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
None.
RBob.
Old Dec 10, 2004 | 09:57 AM
88Z's Avatar
88Z
Car: 88 Iroc
So are you saying that the chip would act normally? Then what's the point in burning the smaller file twice onto the chip?
Old Dec 10, 2004 | 10:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sometimes it's easier to double up the bin and do a full burn instead of figuring out and setting up the address buffers for a half burn.
RBob.
Old Dec 10, 2004 | 11:02 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Basically like RBob says, the 'stack' binary is mostly to keep folks from getting confused about offsets and what-not. If the 16k binary is in the last half of a 32k chip, it'll work fine. If it's in the first half, then the ECU won't see it.
Old Dec 10, 2004 | 06:15 PM
JPrevost's Avatar
Car: 91 Red Sled
Yup, it's weird like that isn't it.
It's just how they made the chips address line pin-outs right? If you switched the last 2 address pins on the 32k it would read the first 16k right? Or am I wrong?
Old Dec 10, 2004 | 07:21 PM
Car: 87 T/A
I think it's just that the pins associated with A15 and A14 on the DIP28 JEDEC layout see 5v from the ECM. That holds em high, and references the top of memory.
Old Dec 10, 2004 | 10:30 PM
88Z's Avatar
88Z
Car: 88 Iroc
If i wanted to read the chip with a tuning program to see exactly what was put on it, how would i go about doing that with only the second part of the chip used?
Mark_ZZ3
May 24, 2018 01:02 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Warlocksirix
Sep 3, 2015 12:26 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
