Pocket Programmer not working
Old Nov 21, 2004 | 08:51 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
My pocket programmer is not working. I have been trying to get it to hook up on both XP home and XP pro machines with no luck.
I sthere something Im not doing right. I had it running on 98 a couple of months ago but that was a company laptop that I no longer have. I plug the thing in and when I run the program it says it cannot find the programmer. Is there something special I need to do in XP, Is there a special program for xp, or is my programmer dead.
Old Nov 21, 2004 | 08:58 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Are you using the "Windows" version or DOS version?
I had no problems using my Windows Verison. But none of my DOS programs work on XP that use to work on W98SE (or WME).
Old Nov 21, 2004 | 09:16 PM
vette9190's Avatar
I've tried both versions with no luck. This is so frustrating, I ve been working on this car for a year now and this is the last step.
Old Nov 21, 2004 | 09:19 PM
Car: Death Mobile
Engine: 666 c.i.
Contact Xtronics and tell them. The Windows Version SHOULD work with XP without having to do anything special.
What version are you trying to use?
Old Nov 21, 2004 | 09:30 PM
JPrevost's Avatar
Car: 91 Red Sled
The motherboard bios configures the parallel port so you need to make sure it's enabled. Go into the device manager and it should be there under ports. If not, the motherboard has it disabled which isn't too uncommon.
Old Nov 22, 2004 | 01:38 AM
ben73's Avatar
Which version number are you using?
Old Nov 22, 2004 | 07:27 AM
vette9190's Avatar
My version is 1.08WB
I have downloaded a demo vesion of the latest software from the web I think is 2.10 but not sure, I'm at work now its on pc at home so I will have to check. But it did not work either.
Old Nov 22, 2004 | 12:52 PM
ben73's Avatar
Thats an OLD version.. Mine wouldn't work with XP till I went beyond about version 1.4x.
Also, check your parallel port settings in the bios, it should be 'std' or 'bi-directional', not 'enhanced' or 'epp' etc..
Old Nov 22, 2004 | 04:10 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
As mentioned make sure the parallel port is enabled (mine needs to be on ECP to allow it to work) as well as the programmer is getting power from its AC adapter.
I have used 1.93 and 1.96 with and without SP1 without a problem.
In XP to get to device manager Right click on My Computer (on desktop)--> Properties --> Hardware Tab --> Device Manager --> then it should be under ports.
See attached image.
Old Nov 22, 2004 | 04:11 PM
eric305TPI's Avatar
Forgot the image.
Old Nov 24, 2004 | 09:36 PM
Car: Death Mobile
Engine: 666 c.i.
If it's a "Pocket Programmer", they are still in business. Just go to www.xtronics.com
If your licence is out of date, they will sell you the latest version for a small fee.
If it's not an Xtronics Pocket Programmer, then none of the software will work and your are SOL.
Old Nov 25, 2004 | 12:00 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Ok, ... this isn't quite pocket programmer related.. but I am a computer tech at Neobox in the Woodlands (You may have heard of it)..
anyway, you need to get those other drivers installed. The USB should be installed once you get some service packs on your machine. I would deffinitely not reccomend running XP without at the very least SP1. As for the multimedia video controller, do you have a TV tuner of some type installed?
Eric, come see me at Neobox, I can help you out if you have any problems. (Plus I want to know someone around here with a chip programmer )
Old Dec 11, 2004 | 12:04 AM
eric305TPI's Avatar
That screen shot was taken about an hour after a fresh install of the OS, I didn't get around to installing everything for a few days. I have heard of Neobox but have never been in there to look around.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
