2732 Prom
Car: '89 IROC
Engine: TPI 383
2732 Prom
I feel stupid for asking this but is there some way to get the chip out of the plastic holder for reading without destroying the entire thing. I am going to use a G2 adapter but still need to retreive the existing code.
Car: An Ol Buick
Engine: Vsick
Re: 2732 Prom
Car: '89 IROC
Engine: TPI 383
Thank you Grumpy. I don't care about the plastic holder breaking but I need the BIN so I have something to work from and don't have to call the recycler to pick up the car.
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I also use a fingertip in the inside to push the chip up against the spring arms as I spread the sides.
You can also remove the 2 bars on top to allow the sides to flex more.
What bin?
It might be avail?
What bin?
It might be avail?
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Moates.net also has an adapter for like $10 that you can plug your entire memcal into and read the existing BIN using your autoprom or Flash-N-Burn....
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
No memcal on a 2732 application.
But, if you upgraded to a '165 ECM, you could then use one of those Moates adapters.
