chip help!!!!
Old Mar 4, 2005 | 09:28 PM
BeaversTA's Avatar
Car: 1993 Z
Engine: lt1
Transmission: t56
chip help!!!!
I have a 93 z28. I am trying to use a G1(ZIF/Chip/Adapter ) with an AT29C256 chip from www.moates.net. I burned it with a BDLD (same as stock) file and tried to install it and every time I put it in the fans turn on and stay on and the car will not run. The car runs fine with the stock mcal in.
Any one know why this is happening? Any help would be great thanks
Rustin
Old Mar 4, 2005 | 11:49 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
This is happening because your bin is not valid. There are a number of potential causes:
1) You didn't burn the bin to the appropriate location on the chip. This likely isn't your problem as you're using a 32K bin on a 32K chip.
2) The checksum is invalid. Make sure it's correct.
3) You're putting the chip in backwards in the G1 or is misaligned in the G1 ZIF
4) Your G1 is not pushed down all the way
5) The chip is not making proper contact in the G1
M
Old Mar 8, 2005 | 05:01 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I'm not an expert on 4th Gens, but I was under the impression that they had a 64K bin because they had a PCM, not an ECM. If so, a "256" is not large enough. You need a "512".
Old Mar 8, 2005 | 05:35 PM
Mangus's Avatar
Transmission: T5WC
94/95 use flash chips. 93 does not.
Old Mar 9, 2005 | 06:41 PM
BeaversTA's Avatar
Car: 1993 Z
Engine: lt1
Transmission: t56
Mangus,
I checked every thing and it looks like I am doing every thing correctly. Can you think of any thing else I should try or check.
Also do I have to use my own stock BDLD file or can I just throw any BDLD file on my new chip and it work?
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
