PROM DIY 'Package'
Car: ‘92 Z28
PROM DIY 'Package'
I have read the stickys and various other posts, but I haven't seen posts that have a 'package' of everthing you need to start and where to buy it. While the stickys are very informative and comprehensive of the things you need, there are so many options out there to sort thru. Is anyone willing to put together a hardware/ software package in a good, better, best format??
Burner, eraser, chip, cables, software, etc-- everything needed to start (minus the computer obviously). I don't mean to actually market it, but just in a sticky or post.
Finding all the stuff is more intimmidating to me than actually burning the chips.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
DIY PROM means do-it -yourself :-)
Hit the stickies and check out TunerCat(which I like and use) and TunerPro(nother neat editor) as far as modfiying your stock tables.
Craig Moates site, also linked has burners and the ostrich and the autoprom(dont wuote me here) and everything else u would need form chips and sockets to cables.
If u do a search here, you will find a million more posts and links with info.
Personally, I use Tunercat and have a pocket prog. 2 and a Romulator w/ all necessatry chips and adapaters.
Read Trax's intro to prom bunring for more info as well
later
Jeremy
later
Jeremy
Car: ‘92 Z28
My daughters swing set, even being sold as a DIY project, still had a list of the lumber and hardware I would need to build it. Didn't have to figure it out completely on my own.
Would you like a refund of the thirdgen.org fees you paid?
Car: 91 GTA - 94 TPI Suburban
Re: PROM DIY 'Package'
Is anyone willing to put together a hardware/ software package ... ??
My example is based on a speed-density $8D mask. So if you are not using a 90-92 speed-density, you will need to research more on the ECM, mask, bin and ECU file that you will need.
Good luck, Ed
Nevermind.
Nevermind.
And given your struggles just figuring out what to buy, I'd say the actual tuning process is going to be real head-banger for you.
Car: 1991 z28
Engine: l98
Hey Kevin, I think you need to lighten up! I didnt read anything that was considered whiny. If you dont want to give an obvious answer, then whats the f*****g point in askin a question? Not all of us are born, or hatched, with the knowledge or experience in tuning our own proms. So the next time you want to insult someone here p*ss off!
BTW, thanx edge, that article was a good help.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
