Question on shift light
Old May 10, 2005 | 05:10 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Alright, by know we have figured out our tachs are off by doing some datalogging. I have looked some of the various shift light parameters have a few questions. Since the shift light comes from the ecm, is the rpms it gathers data from going to be the dataloggers values or the tach on the instrument panel. I'm sorry if that's confusing.
Old May 10, 2005 | 06:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Question on shift light
Originally posted by Gladstoneiroc
. .. Since the shift light comes from the ecm, is the rpms it gathers data from going to be the dataloggers values or the tach on the instrument panel. I'm sorry if that's confusing.
The shift light is based on the ECM RPM value. The tach is a completely separate unit. So, the shift light will match the data logged value, minus the 160 baud ALDL delay.
RBob.
Old May 12, 2005 | 11:42 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Rbob,
Did anyone ever figure out how to change the RPM that the "shift" light comes on at? I know there are the looooonnng posts about doing it, and I would hate to go back and read them to discover it had not been done yet.
Old May 12, 2005 | 01:02 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep - It's in TunerCat, at least for the 730 with $8D mask. Might have to contact him to get the update, but it's there and works great!
I necessary, I can get the hex addresses where the data is stored, but I have no idea what the fomat of the data at those locations is....
Old May 12, 2005 | 01:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by Tibo
Rbob,
IIRC myself and someone else posted the complete run down of converting the shift light into an RPM only based shift light. We both posted to the same thread. And, IIRC, it was for the '8746.
RBob.
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
