spark advance readings with tunerpro
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
on my spark table is the value shown have the 6 degrees of timing included? or do i need to add it in? just started into tuning and wasnt sure... thanks
clayton
clayton
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
As long as the base spark constant in your bin is set so that it matches what's physically set on your distributor, you don't have to add or subtract anything.
Edit: Don't forget that there may be other corrections applied, for coolant temp, PE spark, etc. in addition to the main spark table.
Car: 91 Red Sled
There isn't 1 table that reflects the engines actual timing and depending on the software you're using it might be more intuitive. I have all my xdf files setup so that the table bias is included in what is displayed. This helps with the correction tables. The main SA table also might have a bias, again, it depends on the software. The initial SA or base SA value should match the actual engine's base timing. Do that and the main tables will then be the basis.
