Tuning v6 Firebird with Autoprom
Car: 92 Firebird
Engine: 3.1 V6
has anyone been able to datalog with their autoprom on a 3.1 liter v6 firebird. i think 90-92 are the same ecm and engine size. i have the 730 ecm and my autoprom is recognized by tuner pro, i have autoprom version 2.8 and the software recognizes it but when i go to datalog it will no connect to the ecm. i am using the 8d aldl datastream for the v6 and it wont do anything but say not connected. i have also tried other 8d files but still does the same thing. i built a 2 transistor cable to datalog with a long time ago and it did the same thing, so i figured i did something wrong and just purchased an autoprom because i want to be able to tune also. well, this doesnt work either. its a usb based autoprom if that makes a difference. any help will do me wonders. -Matt
Car: check
Engine: check
Transmission: check
Need to use an $88 data stream file. Don't know if there is one around for it or not. I do know that the $8D data stream file won't work. The header values are different.
RBob.
RBob.
Car: 92 Firebird
Engine: 3.1 V6
ok i have tried the $88 mask today since i got home and it still does the same exact thing. attempts to connect and then says not connected. i dont know what to do, i have searched to see if anyone else has had this type of problem and couldnt find anything like it.
Car: 92 Firebird
Engine: 3.1 V6
i got the ads file from moates.net its the 1227730_V6_90-92 file with the $88 mask. if i keep trying to connect it will connect sometimes but then the error count will just steadily rise and nothing reads out on the sensor data. yes i tried passthrough mode. it wont even connect at all in that mode. from what i have read and can figure out i thiunk it is just the ads file that is keeping it from communicating, but i dont know what to change at all.
Car: 92 Firebird
Engine: 3.1 V6
the vertical switch is in the center but i have tried eiter of the other two sides with no luck. its a usb autoprom i didnt think i had to select a com port.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
In passthrough, yes, you do. You need to select the COM port that the USB driver is installed on.
See the bottom of this:
http://www.moates.net/documentation....entation_id=15
Car: 92 Firebird
Engine: 3.1 V6
thanks for the help guys, turns out it was a mix between using the wrong comport and having the wrong definition file selected. i was using $8d instead of $88. and i had com 5 selected in the hardware profile and tunerpro. seems like it should have worked but i changed them both to com 3 and now it all works properly. thanks for your help guys.
tyeo098
Nov 30, 2015 06:27 PM
