Stock Prom EGR Question????? Please help & Read
Old Jul 25, 2005 | 08:49 PM
ZZ4-GTA_Mike's Avatar
Car: 1989 Flame Red GTA
Engine: ZZ4-350
Transmission: Junk automatic
Hey guys, I installed a ZZ4 motor in my 1989 GTA about two years ago. I removed the catalytic converter (i do not have headers yet) I removed my smog pump and all other smog related equipment, I installed a Walbro 255 LPH fuel pump, acell 24lb injectors, Holley adjustable fuel pressure regulator, and a ram air setup (K&N). Now here is the problem, The ZZ4 motor does not have EGR passages so I purchased a EGR block off plate from T.P.I.S. I had the timing on the car set at 10 degrees BTDC, and the car pinged like crazy on accelaration. So I dropped the timing to 7 degrees BTDC. (I always use premium gas also) I notice a loss of power and the pinging is still there. It is slightly better, but still bad. What I want to know is is there any way to get my stock prom sent somewhere that they can remove EGR from it?? Then I can bump my timing back up etc. I am not mooching, etc, I am willing to pay, or would like to find out where I can send my prom to have this done. So I can advance the timing again, and get some more power. Right now I am afraid to lay into the car because of the pinging. I need some expert help, that is why I am here Please help, or tell me what I can do. Sorry for the long post, this is just driving me crazy, and I just want to get it right. Thanks in advance guys!!
Take care
Mike
Old Jul 25, 2005 | 10:00 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
just turning off the EGR won't fix what you want it to. there is more to it than that. you really need to do it yourself to get a good chip.
i have seen what is done to some of those "performance chips",
over $300.00 just to turn off VATS & dump more fuel into it only for it to run worse than what it did with the stock chip, what a joke.
for what a chip would cost you, you could buy the stuff to burn your own & have something the motor really likes, plus some extra cash in your pocket.
read through the stickies up at the top of this board, once you learn how & what all you can change, i think that is the way you'll want to go.
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
camaroken83
Aug 10, 2015 11:35 AM
